8" Rear end question?
Old Aug 13, 2004 | 07:54 AM
Woodsman_30350's Avatar
Woodsman_30350
I have a 8" rearend from a Mustang that I am putting into a 1950 F-1 with a 302/C4 combo. I want to change the gear ratio from the 2.79 in the current third member. I am doing a salvage yard search and need to know what years the 8" was used and in what vehicles. Any help is appreaciated
Old Aug 13, 2004 | 12:20 PM
85e150's Avatar
85e150
Check out these boys:
http://www.currieenterprises.com/
Check their "Alumin8" item. Lightweight, high strength 8" diff. $390 or so.
That's as far as I went looking, not sure about details.
As for factory 8": These were in small block V8 small and intermediates like Falcon, Mustang, Fairlane, Comet etc.
These diffs ran from the early '60s to probably the mid '70s.
This is another guy selling 8" diffs. Looks like he sells Currie stuff. See the site and get the info:
http://www.davidkeetoploaders.com/thirdmembers.htm
You may luck out and get one from the scrappy, but these were kind of a weak diff and if they've been out in the elements for years, you could have real howler with used one. (like the one I got for $50 in 1971.)
Old Aug 13, 2004 | 12:36 PM
RTM's Avatar
RTM
Mustang II's are your best for finding a set of gears. Buying used 8 inch gears can be exspensive and hard to find. If your looking for a trac loc then be ready to pay for one. About twice the cost of a 9 unit.
Old Aug 13, 2004 | 08:39 PM
85e150's Avatar
85e150
Also, your Mustang housing may be a real lightweight....they warn against using the 9 inch Mustang housings....., not sure if there is a lightweight 8" housing.
Old Aug 14, 2004 | 07:24 AM
RTM's Avatar
RTM
There are banjo style housings that are weaker than the newer style truck housings. Banjo style housings couold be found in older trucks as well as cars.
98Econoline150
Feb 16, 2017 04:36 PM
less
Flathead V8 & Flathead 6
32
May 12, 2009 04:30 AM
Supercab
Sep 20, 2008 07:54 AM
aircraftfixer
Feb 6, 2007 02:29 PM
oldhalftons
Jun 26, 2004 04:47 PM
