302 Cam
Old Aug 13, 2004 | 12:31 AM
fordflaresides's Avatar
fordflaresides
302 Cam
What's the most aggresive cam I can run in a 302 out of a '73 F100 with the stock bottom end and heads(Compression 8.?:1)? Has a Edelbrock 4bbl intake and carb.
Old Aug 13, 2004 | 07:26 AM
mark a.'s Avatar
mark a.
A guess would be somewhere around .530 lift with stock rockers, before you would start to run out of valve to piston clearance. But I would still check the valve clearance you need at least .080 - .100. With lower comp. engines you should run as much lobe spread as possible, 112 or 114.
my91stealth
Dec 1, 2010 04:53 PM
Fordever2
May 25, 2005 09:19 AM
tomw
Dec 3, 2002 12:27 PM
302man
Feb 13, 2002 06:06 PM
