Sponsored by: Auxito
Am I Underpowered??
Old Aug 12, 2004 | 07:37 PM
DRP's Avatar
DRP
Am I Underpowered??
Got a concern. I have a 97 4.6L F-150 4x4 with a limited slip. It has about 120k miles on it, and I think its lost power over the years. From what I've heard, the 4.6 can still burn tires even with a limited slip. Mine can't. I dont know if it's because I have larger AT/S tires or what, but it wont even come close to burning out. Will someone please tell me if I am underpowered? BTW, I'm talking about a brake stand here, not just a "gas and spin" type burnout.
Old Aug 12, 2004 | 10:35 PM
Tom's Avatar
Tom
Larger tires would limit the torque the truck could put onto the ground. Also, what is the gear ratio for your rear axle? I know they put the 3.06 ratio with the 4.6, which is meant for gas mileage instead of power. With 120k on the truck, there shouldn't be much power loss due to engine wear. The engine could have a problem that would limit power, but just not being able to burn the tires isn't a definite indication of power loss.
Old Aug 13, 2004 | 07:06 AM
bigmack's Avatar
bigmack
I have a 5.4 in my 98 flairside kingcab F-150 and cannot burn tires. Of course I run 295.75.16's so I believe that is my issue.
Old Aug 13, 2004 | 08:48 AM
kenwhelan's Avatar
kenwhelan
Have you changed the fuel filter lately. That is what killed my gas mileage in my current setup. I've got Cooper A/T tires standard size on mine and I can spin them a little, not a lot. If I've got any weight at all in the back, even a couple of hundred lbs I cannot spin them.
Changing the fuel filter was like night and day as far as power on my truck.
Old Aug 13, 2004 | 02:20 PM
kenwhelan's Avatar
kenwhelan
I meant to say above that is what killed my power, (maybe my mileage too).
KY Thomas
1997 - 2003 F150
Aug 8, 2013 08:39 PM
jwth2005
1997 - 2003 F150
Feb 22, 2011 12:20 AM
mnmfors
1997 - 2003 F150
Apr 18, 2010 12:18 PM
Rcmgiasson
1997 - 2003 F150
Oct 17, 2005 11:36 PM
vettethret
2004 - 2008 F150
Jun 9, 2005 12:04 PM
