Geasing ball joints?
Old Aug 12, 2004 | 06:50 PM
whphel's Avatar
whphel
Greasing ball joints?
I bought a 2000 F-250 SD about a month ago and I just crawled under it to grease the ball joints. Anyhow, I Found only for grease fittings under the whole truck which after doing a search seems to be correct. While doing a search I found a post that said "just make sure you dont break the seals", Well I slowly pumped grease into the ball joints and it seams and looks as though the seals are made with a very small hole in them to drain excess grease from.
Are those holes supposed to be there(1 per seal)?
Old Aug 12, 2004 | 07:28 PM
tjbeggs's Avatar
tjbeggs
yes the hole should be there. as far as i know. i have installed replacement ball joints that have holes to drain grease out. i generaly pump it in until a small amount of grease comes out of the boot. boots are all made a bit different. some are just a slip fit over the joint and some are sealed tighter. hope this helps
tjbeggs
Old Aug 12, 2004 | 07:33 PM
whphel's Avatar
whphel
Thank you! Just wanted to double check. My 86' F-250 has the slip overs and grease flows out of them.
