I notice under the dash there's several wires coming out of a wire loom .
The red,white,blue and black goes inside the engine compartment, the other 4 wires are for what ?
04 F350 CC SRW LB
Thanks !!!
Are you talking about the spare wires Ford stubbed up thru the firewall to save you from having to punch a hole thru there ?
you can use them for what you want (if they are the proper gauge )
There are eight wires under the dash that Ford stubbed up .
I see the four wires (solid color) that goes through the firewall and ends up in the engine compartment .
I don't see where the other four wires (solid with stripe) ends up .
Sometimes I'm blind in one eye and can't see out of the other .
Are they in the engine compartment too ?
Also these wires have some sort of rubber/plastic coating on the tip .
