Quick Response Please
Old Aug 11, 2004 | 10:30 PM
Monster Duty's Avatar
Monster Duty
I'm hooking up a boost gauge tonight and trying to tee into the map sensor , BUT not sure where the map sensor is ?
Help Please !!
Picture would be great .
Thanks In Advanced
Old Aug 11, 2004 | 10:49 PM
Hayapower!'s Avatar
Hayapower!
Map sensor is mounted 'on top' of the A/C evaporator box.. Near the blower motor.. It has 3 studs with nuts sticking 'up' attaching it and bracket to the box.. Passenger/right side at the firewall.. It also has a rubber hose/red spring clamps that attaches to the intake.. Good luck with the install..
........................HP................
Old Aug 11, 2004 | 11:22 PM
Choctaw Bob's Avatar
Choctaw Bob
A foot or so to the left of the turbo as you stand on the front bumper.
Old Aug 11, 2004 | 11:28 PM
Monster Duty
Thanks HP
I think I'm stuck tonight .
I'm actually hooking up a X-Monitor and was drilling for the pyro starting small and steping up in drill size . I get to the 7/16 bit and can't locate my 1/2 inch drill......I tried using bubble gum and duct tape in the 3/8 drill with no luck
Oh well I'll finish up tomorrow
Thanks again!!!
Old Aug 11, 2004 | 11:29 PM
Monster Duty
Thanks CB
Old Aug 12, 2004 | 07:51 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
FTE is better than having a tech in your garage...plus we are all house broke
Old Aug 12, 2004 | 08:33 AM
jdadamsjr's Avatar
jdadamsjr
Speak for yourself
That's why the new house has a smaller "house" out behind the trees
Old Aug 12, 2004 | 09:20 AM
$trokin60's Avatar
$trokin60
Monster duty If I may make a suggestion. forget about going into the map sensor if you have a 2004 it will cause the gage to fluctuate. I ended up tapping into the intake elbow. when I had it in the map sesor I could'nt even tell what the boost was it fluctuated so bad and made a loud buzzing sound. After tapping the intake elbow, it works perfectly. Hope this helps. Jerry
Old Aug 12, 2004 | 12:03 PM
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
Hmm... Im not sure about this, but I think something else is going on. I have the attitude monitor spliced on the MAP sensor line and it is solid as a rock...
What kind of gauge do you have?
Old Aug 12, 2004 | 10:15 PM
tsheriff's Avatar
tsheriff
Mine is taped into the map line too. no problems either. The line comes straight up out of the pass i think valve cover and sticks into the bottom of the map sensor. Maybe 10" of rubber hose wrapped in plastic.
Old Aug 13, 2004 | 10:01 AM
mikeyG9's Avatar
mikeyG9
I had the same problem the other night! Mine ('03) MAP line is red but is covered completely with the same sheath as all the wiring, so I was looking right at it for 30 minutes. Like the guys said, pass side "valve cover" up to the MAP which hangs on a bracket on the firewall.
Mike
Old Aug 13, 2004 | 11:19 AM
$trokin60's Avatar
$trokin60
The fluttering only happens on the 2004 models for some reason. I never had it happen to my 1996 or the 2003. The gages are banks. there is a big discussion about this on another site. When I said above that is fluctated, that was a missunderstatement it actualy fluterd from 30 down to zero and back. All is fine now that I have tapped into the intake elbow where some of you guys installed water injection nozzles.
Old Aug 13, 2004 | 04:08 PM
Monster Duty
You are right Tim !!! Everyone here is AWESOME !!!
I have another question for everyone .
Where did you guys tap in for a power source for your gauges ?
I notice under the dash there's several wires coming out of a wire loom .
The red,white,blue and black goes inside the engine compartment, the other 4 wires are for what ?
04 F350 CC SRW LB
Thanks !!!
Old Aug 13, 2004 | 06:56 PM
Maxium4x4's Avatar
Maxium4x4
I use a five gallon bucket.... and a towel so I don't scratch the paint on the fender.
Remove the cover under the steering column:
You will see a (red with yellow trace) wire for switched ignition power. Instrument lighting power (yellow) 2nd from the top left of the grey connector.
Old Aug 13, 2004 | 08:10 PM
Monster Duty
Anyone else with a 2004 6.0L have this problem ???
Thanks for the help Maxium4x4
