Speed sensor problems, need help Badly!Experts welcome.
Old Aug 11, 2004 | 06:45 PM
scottya4's Avatar
scottya4
Ok, I've been having problems with my shifting and speedometer. My speedometer doesnt move at all till about 40kms per hour, and then it flickers up and down very erratically. Once hitting the first shift in the automatic transmission it shifts about 2 seconds too late and someone "bucks" me. I read a prior post that said change the speed sensor in the differential which i did, and it did not help. So now I'm not sure what it is. I picked up a speed sensor for the transfor case, and went to check out the transfer case to find where it goes in and its nowheres to be found, so that can't be it. Had a mechanic friend look at it and he said that sensor in the rear end should be the problem, so I'm not sure whats going on?? Could there be rust or dirt underneather the sensor in the hole that may be blocking the sensor? Or maybe it is the wire that clicks into the sensor that is not working properly? Any help would be HUGELY appreciated as this problem is really starting to get to me, help please!
Old Aug 11, 2004 | 07:08 PM
scottya4's Avatar
scottya4
another question, would it hurt to spray water in the whole and then drying it with a rag to clean any rust etc out of the whole it goes in?
Old Aug 11, 2004 | 07:27 PM
pfogle's Avatar
pfogle
I would have your mechanic friend pull the cover off of the differential, sound to me like a bad tone ring.
Old Aug 11, 2004 | 07:28 PM
EPNCSU2006's Avatar
EPNCSU2006
Don't spray water in there. It goes straight into the rear end, and so all that water will get mixed with the grease, and it won't be pretty. It's a magnetic sensor, so dirt shouldn't affect it. At this point, I would suspect the wiring more than anything. You'll have to trace it somehow and see if you can find a point where there is a break or a short. Might also want to check the connection with the cruise control.
Old Aug 11, 2004 | 07:45 PM
scottya4's Avatar
scottya4
doesnt have cruise control.
Old Aug 11, 2004 | 08:01 PM
pfogle's Avatar
pfogle
Scotty, what engine and year is this truck? If it's an AOD then there should be a speed sensor sticking out the side of the transmission.
Old Aug 11, 2004 | 08:19 PM
scottya4's Avatar
scottya4
its a 1993, F150, with a 302 motor. I already replaced the speed sensor in the rear end.
Old Aug 11, 2004 | 08:30 PM
pfogle's Avatar
pfogle
Auto trans or manual? If it's a manual then you probably don't have a speed sensor in the trans.....
Old Aug 11, 2004 | 08:42 PM
scottya4's Avatar
scottya4
no no its automatic..... maybe its the wire that plugs into the sensor on the differential... who knows.
Old Aug 11, 2004 | 08:49 PM
pfogle's Avatar
pfogle
If replace the sensor didn't fix it, it's gotta be in the wires, pull the dash apart and make sure the connector there is fully plugged in.....
Old Aug 11, 2004 | 08:52 PM
scottya4's Avatar
scottya4
yeah ill have to look into it, thanks, if anyone else has an idea lemme know.
Old Aug 15, 2004 | 11:24 AM
scottya4's Avatar
scottya4
good news, all fixed and shifting better then when i bought it, had my mechanic disable the abs computer, his words were " I over rided the abs computer" therefore taking away my abs breaks but thats fine with me, as long as it shifst nicely and the speedo works!
Old Aug 15, 2004 | 02:52 PM
omni's Avatar
omni
why did your mechanic say the abs computer was messing it up? just curious. Randy
Old Aug 15, 2004 | 05:53 PM
scottya4's Avatar
scottya4
he didnt say why, I didnt ask, lol, i was just glad to have her fixed.
Rentaro
Feb 18, 2016 03:15 AM
achyness
Mar 11, 2015 02:58 PM
charles5000
Jan 28, 2014 07:31 AM
mekanikman_402
1997 - 2003 F150
Apr 21, 2012 03:02 PM
jdcrew
Apr 29, 2011 11:57 AM
