oil pan question
Old Aug 11, 2004 | 01:53 AM
hood's Avatar
hood
oil pan question
1991 Ranger 3.0L
On the right side of my oil pan there is a plug with an orange wire that runs up to the oil sending unit. What does this plug sense from the oil pan? It is also the source of some oil leakage. Can this be tightened up without causing any problems? Thanks.
-hooD
Old Aug 11, 2004 | 08:55 AM
Gary B's Avatar
Gary B
hood, it is a low oil level sensor,turns a light on when the oil is low. tightening it may help,try it, ir not just remove it and replace the gasket
Old Aug 11, 2004 | 02:35 PM
Rockledge's Avatar
Rockledge
Might as well pull it, clean it all off, and reinstall it with a new gasket (if it uses one).
Old Aug 12, 2004 | 01:05 AM
hood's Avatar
hood
Thank you both very much for the info, i will try removing, cleaning, and re-installing. Should i assume that when i remove the plug, the oil will want to drain out also? If so, then this should be done during the next oil change.
-hooD
jonrjen
6.7L Power Stroke Diesel
29
Aug 30, 2014 07:49 PM
JetFuelBurner
Jan 9, 2013 05:58 PM
alvald83
Oct 5, 2012 11:35 PM
VH_Girl
24
Feb 27, 2012 08:48 AM
Snakedriver
Jan 21, 2012 09:25 PM
