coolant leak
Old Jul 7, 2001 | 08:11 PM
dinger's Avatar
dinger
coolant leak
I have a 1996 explorer that is leaking coolant. the only place I can find that is wet is the upper radiator hose. while idling, no leak. step on the gas pedal and coolant sprays off of the fan onto upper radiator hose. it has the 5.0. thank you in advance for any replies
Old Jul 7, 2001 | 08:20 PM
whomrig's Avatar
whomrig
coolant leak
Try tightening the hose clamps, check again. If these are original hoses, replace 'em...There may also be a pinhole leak in the rad itself.
Wayne 60 F-350
e-mail
https://www.ford-trucks.com/users/whomrig
Old Jul 8, 2001 | 05:58 PM
spydermandb's Avatar
spydermandb
coolant leak
might also be the expansion plugs in the engine. one might of rusted through. it happened on our '97 taurus, it was leaking coolant off the engine, and was overheating. turned out that an expansion plug rusted through and had a pinhole leak in it. weird and rare...yes...check it out if replacing the hoses and tightening the clamps does not work.
Old Jul 9, 2001 | 01:08 PM
sirknight2's Avatar
sirknight2
coolant leak
[font size="1" color="#FF0000"]LAST EDITED ON 09-Jul-01 AT 02:13 PM (EST)[/font][p]I'm having somewhat of a similar problem as Paul, I have a 98 Explorer Sport, I've added at least 2 full gallons of engine coolant in it over the past month.....also, I continuosly get a check gage light even though everything that could be filled is filled.........any help on this is also appreciated....by the way, I'm new to this chat stuff, so please be easy on me..
Old Jul 10, 2001 | 08:35 AM
jcmac's Avatar
jcmac
coolant leak
eigenvector
1983 - 2012 Ranger & B-Series
Mar 8, 2011 08:11 PM
powerstroker100
Oct 24, 2010 07:54 PM
whatdyisit
Nov 21, 2004 08:47 AM
explodead
Dec 11, 2003 08:31 PM
fordmarshall111
Nov 19, 2003 06:38 PM
