302 efi rebuild
Old Aug 9, 2004 | 04:06 PM
allford86's Avatar
allford86
302 efi rebuild
We rebuilt a 351 and had to use the 302 firing order. I am planning on rebuilding my 86 ford 302 efi and if i use a cam that needs the 351 firing order will i need a new computer?
Old Aug 12, 2004 | 09:52 PM
terryr's Avatar
terryr
You can switch around the injector wires. It usually works.
Old Aug 13, 2004 | 09:07 PM
allford86's Avatar
allford86
thanks but now i am thinking of putting that 351w with the 302 firing order into my 86 will that computer run that. All i think i need are the manifolds.
Old Aug 15, 2004 | 02:59 PM
drewcoolness99's Avatar
drewcoolness99
all you should need is the lower manifold the upper of both are the same i believe. (<--assumes you already have the upper)
then you can have a 351 that says 5.0 on top
Old Aug 21, 2004 | 10:32 PM
allford86's Avatar
allford86
yes i have all efi still in my 86. Will the injectors go into the 351 manifold out of my 302 manifold
Old Aug 22, 2004 | 11:36 AM
drewcoolness99
i think i might be wrong but I think the fuel rails are different sizes. I think 351's have longer ones. But the injectors should be interchangable. But if you plan on making more than 310 hp you might consider upgrading. (according to http://fordfuelinjection.com) if you go there then go to actuators and click the fuel injectors pic it has all the ratings for them at the bottom.
Cstout
Nov 2, 2015 07:48 PM
dunk999
13
Jan 1, 2015 08:48 AM
Motorhead351
WTB - Parts & other
Jul 7, 2014 10:12 PM
1990-f250
Jun 15, 2014 11:59 AM
craigibc
Aug 15, 2010 10:14 PM
