98 explorer transponder key
Old Aug 15, 2001 | 09:21 AM
evans's Avatar
evans
Did all 1998 explorers come with transponder ignition keys?
Only the 5.0 litres? Only Eddie Bauers?
Thanks,
Mike/Ohio
Old Aug 15, 2001 | 01:22 PM
reberhardt's Avatar
reberhardt
If you are referring to the SecureLock (or was it SecureTheft?) system that was introduced in '98 then yes, all Explorers have it beginning in '98.
Old Aug 19, 2001 | 03:00 PM
fauxexplorer's Avatar
fauxexplorer
and rangers if you have both original keys.you can reprogram as many as you want.the procedure is in the manual
Old Aug 22, 2001 | 06:24 AM
bubbaredneck's Avatar
bubbaredneck
Old Jun 28, 2004 | 10:13 PM
Msp541's Avatar
Msp541
Yes the 1998 and up all came with a transponder key and if you need a replacement key at half the cost go to EBAY the cheapest place to get one and the programming is very easy check your manual.
Good Luck!
PeteCress
2004 - 2008 F150
Dec 19, 2016 08:21 PM
earlybirds
Dec 3, 2016 10:10 PM
Spotty
1997 - 2003 F150
Mar 22, 2014 07:34 AM
EXv10
Mar 4, 2014 09:10 AM
Mikey D1016
2009 - 2014 F150
Apr 30, 2009 10:38 AM
