Computer Chips & Tuners
Can't find computer code, Please help, I want to order
Old Aug 8, 2004 | 08:20 PM
scout72's Avatar
scout72
I have searched under the hood on wiring, under the dash kick panels, no code, I have taken the silver box out and the only code I have foung in F1TB on computer box. Iwould like to order but all my searching is taking me no where. Please help.
Larry
Old Aug 8, 2004 | 08:24 PM
FTE Ken's Avatar
FTE Ken
Sorry, that's the beginning of a part number, not a code. The part number indicates its a 1991 part. The PCM code will be on a white sticker, about the size of a postage stamp, on the back side of the computer box (opposite the place where the wiring harness connects). Take the box out to see it.
Old Aug 9, 2004 | 06:24 AM
scout72's Avatar
scout72
Ken,
Took the computer box out this morning and no sticker. Someone has done some work to the truck before but I can't get in touch with this person so I am having to go from what I see. Someone removed the smog stuff and installed dual flowmasters with 3" pipes. I believe that it has a shift kit by the way it shifts. It has a K&N replacement filter. It also has 33 in. tires if that matters. The motor is a 5.0L. The rear axle ratio is 3.31. Thats all I know about the truck but your help would be appreciated, I am stuck.
Thanks Larry
Old Aug 9, 2004 | 11:35 PM
FTE Ken's Avatar
FTE Ken
Unfortunately without the PCM code I can't program a chip for it. Give me everything printed on any decals on it.
Old Aug 14, 2004 | 09:44 AM
scout72's Avatar
scout72
Ken,
Sorry I haven't got back sooner but been working 12 hours a day this week. I got these number off the computer box F1TB-7E453-AA and a # below that 4613 or 46I3 can't make out it out. The other number on the wiring harness going to computer is N160L. Hope this helps and I appreciate your help very much.
Thanks Larry
Old Aug 14, 2004 | 12:32 PM
FTE Ken's Avatar
FTE Ken
I'm afraid I'm not going to be able to help you. I simply have to have the PCM code because I can't cross reference any of those codes you gave. Sorry.
Brian Goodman
May 16, 2016 01:59 PM
cjben
Jun 30, 2015 04:21 PM
quincyj34
May 17, 2015 10:47 AM
KrazyKs Motorsports
Dec 19, 2011 08:28 AM
savaunte
Feb 10, 2005 06:44 PM
