Gas Tank Troubles
Old Aug 7, 2004 | 09:24 PM
77Highroller's Avatar
77Highroller
Question Gas Tank Troubles
I just got a new gas tank from Aero tanks for my 1977 F-250 Highboy. When the tank mounts are resting tightly on the frame, the filler neck is not in the right spot. Has anyone else had this problem with these tanks, and if so how did you fix it? I was going to try moving the filler neck or putting a new one on with a 45 degree bent in it. Hopefully there is a much better way.
Thanks.....................
Old Aug 8, 2004 | 01:01 AM
matt77F2504x4's Avatar
matt77F2504x4
might be a serial number thing. what's the VIN?
Old Aug 8, 2004 | 03:44 AM
fordflaresides's Avatar
fordflaresides
I would call Aero Tanks and make sure they gave you the right tank and if so what their suggestion is.
585eric
WTB - Parts & other
May 25, 2013 08:55 PM
HotrodSmurf
18
Sep 3, 2012 07:52 PM
okwaho1650
Mar 2, 2012 09:00 AM
solaratomic
Apr 11, 2005 07:52 PM
wmodon
Aug 16, 2004 07:50 PM
