Fule Pump
Old Aug 7, 2004 | 03:38 PM
SethOveson's Avatar
SethOveson
Fule Pump
I just finished rewiring a 1950 F1 but I now have to deal with the fule pump. It looks like they put on an electric fule pump after the original stopped working. Niether one work now so I need to put in a new fuel pump but should I replace the original or just put in another electric one.
Does anyone know the pros and cons. also the fule lines need to be replaced should I use Copper lines or rubber.
Any help would be nice I am new at this
also I am getting ready to do body work and would like to know the best way to get all the rust and old paint off. Would Sand blasting it dammage the metal to much. how is the best way to clean up the inside of the cab
Old Aug 7, 2004 | 05:13 PM
sevenL4's Avatar
sevenL4
NEVER use copper for fuel lines. It breaks too easily. Use steel whenever and wherever you can. Avoid using neporene anywhere you cannot inspect it regularly. Only you can prevent car fires
Old Aug 7, 2004 | 05:50 PM
himmelberg's Avatar
himmelberg
Welcome, Seth. Seven has it right about the copper tube... it gets work hardened from normal vibration... use steel brake line, its not hard to deal with. Use "rubber" fuel line between the frame and fuel pump and the steel line into your carb and on either side of your fuel filter. Helps dampen vibration.
We need to know what engine and carb you have before the definative fuel pump answer is available. If you have a flathead and Holley 94 type carb, be aware that that carb doesnt like much more than 2 to 2.5 # of pressure from the fuel pump. Good luck. himmelberg
Old Aug 9, 2004 | 12:22 PM
SethOveson's Avatar
SethOveson
Thanks I will look at the model # of the Carb but it is a flathead v6, it was my father in laws and my brothers and I are trying to get it working again, once it is running then we are going to restore it as much as we can.
Old Aug 9, 2004 | 07:46 PM
four8fordf1's Avatar
four8fordf1
Interesting, I purchased a 48 Ford F1 Flathead 6 and it also has an electric fuel pump. It starts and runs fine, but when you initially turn on the switch, a small amount of fuel leaks from the carb and runs down the side of the carb and intake. I would like to take it back to stock and am wondering if Ford had a lot of problems with these flat head sixes with stock vacuum fuel pumps. Don't like the mess the leaking is making and I am concerned about the safety as well (fuel leaks seem like a fire just waiting to happen). I will follow this thread to see of other have additional information about this subject.
Old Aug 9, 2004 | 07:57 PM
sevenL4's Avatar
sevenL4
four8...
Take note what himmelburg said about fuel pressure. Your pump is overcoming the needle and seat. Get a pressure regulator to put in line between the pump and carb. Meanwhile buy a sign that says "NO OPEN FLAME WITHIN 50 FEET". That should prevent the fire that's waiting to happen
ah1988
16
Feb 14, 2020 03:42 PM
dougs521
Oct 3, 2012 09:06 AM
ah1988
Sep 30, 2010 05:14 AM
ah1988
Sep 26, 2010 01:01 PM
CRGIFT
New Member Introductions
Jan 8, 2007 07:26 PM
