HELP, transmission woes!
Old Aug 6, 2004 | 07:04 PM
TJDREAMS's Avatar
TJDREAMS
Unhappy HELP, transmission woes!
I want to keep my 300 I6 in my 1970 F-350 dually, but i'd like to switch from manual to automatic transmission. Is that feasable? I mean, can u just swap my 4 speed to a C6 auto with the bellhousing being the same, i just don't think im that lucky. And also, do i have to switch the flywheel to a flex-plate. PLEEEEEZE, help....
Old Aug 6, 2004 | 09:24 PM
Jimbare's Avatar
Jimbare
all alone in the world
you will have to swap the flywheel to a flex plate. you will need a tranny from a 240/300, or 289,302,351w. you will also need a driveshaft, [front section only], a radiator with a tranny cooler in the bottom, and a steering column.
make sure you get all the nuts and bolts, and all the shift linkage parts also, that way if any are differant you will have them.
jim
Old Aug 6, 2004 | 09:59 PM
TJDREAMS's Avatar
TJDREAMS
Question I don't seem to follow on the radiator part
looking at Mac's catalogue, radiators available for a 1970 f with a 300 does not specify automatic or standard shift, only 73+ models do, i understand the need for transmission cooling, i just changed my 4r100 in my 2001 F-350 but is it possible that the original c4 tranny did not NEED a transmission cooler?
Im pretty confident that automatic was an option on 1970 models, but im not so sure about the radiator as it seems that mounting flange location, air/no air does make for different versions. My original is a rear flange, no air version.
Old Aug 6, 2004 | 10:39 PM
Jimbare's Avatar
Jimbare
i have 3 differant year trucks, 69, 70, and 72. all have the tranny cooler in the rad. i have seen earlier trucks without the rad cooler. they had a cooler mounted on the tranny. i dont think they worked very good though, if they had i think they would still be using them.
jim
Old Aug 6, 2004 | 11:23 PM
Torque1st's Avatar
Torque1st
Posting Legend
Parts for older vehicles sometimes become generic versions that work for the greatest number of applications. You need a transmission cooler and the radiator mounted ones serve two purposes. They cool and heat also.
I transmission from a 300-6 would have the best option since the valve body etc would be set up for the proper shift points. You could even go with an AOD and have an OD for economy.
Old Aug 6, 2004 | 11:36 PM
TJDREAMS's Avatar
TJDREAMS
I thought that c4 auto had OD as a standard feature, for sure the c6 does, can anyone confirm this. Excellent point, Torque1st, i never thought about the shift points, too used to comp. controlled new trannies that are so to speak plug-and-play.
I hope rad w/ oil cooler will fit into current mount.
Old Aug 7, 2004 | 04:15 AM
banjopicker66's Avatar
banjopicker66
OD functions within the C-6 and C-4 did not become available until the early '80s.
I am putting a Doug Nash OD unit behind the '69 C-6 going into my '66 F-100.
Old Aug 7, 2004 | 04:30 AM
Torque1st's Avatar
Torque1st
Posting Legend
There were no OD C4's or C6's. The AOD is the only "dumb" overdrive auto tranny available that I know of. The later models like the E4OD that shares a few common parts with the C6 is electronically controlled but I hear you can get a brain box. The AOD will work just fine behind a 300-6 or even a mild 351W and is available at a much lower cost than any of the other options. HD versions of the AOD are available from some builders.
Old Aug 7, 2004 | 04:32 AM
banjopicker66
You put it better than I did.
Thanks.
Old Aug 7, 2004 | 04:38 AM
Torque1st's Avatar
Torque1st
Posting Legend
UR welcome, been doing this for a while
The AOD will probably help a LOT with a F350 dually since it probably has a very low rear axle ratio with that 300-6.
