Idle Trouble, Code 121
Old Aug 6, 2004 | 05:04 PM
mmendell's Avatar
mmendell
Newbie to the forum.
I've got a '95 F150 5.8 with 210K miles on it. My idle speed has recently gone extremely high. I pulled a 121 code (Closed throttle voltage higher or lower than expected).
I just spent $1400 on various repairs (mostly front-end) but including the EGR valve. I would like to do this one myself!
Any ideas?
Thanks!
Old Aug 7, 2004 | 12:26 AM
drewcoolness99's Avatar
drewcoolness99
TPS maybe?
Old Aug 7, 2004 | 05:52 AM
larry derouin's Avatar
larry derouin
Agree with Drewcoolness99. TPS
Old Aug 7, 2004 | 08:44 AM
mmendell's Avatar
mmendell
Is there a way to check this?
Thanks for the input!
Old Aug 7, 2004 | 10:15 AM
EPNCSU2006's Avatar
EPNCSU2006
Yes. You'll need a volt meter to test the tps, but it is a simple check. With the key on (engine off) first probe the orange wire to make sure you have 5V between there and the black wire on the tps connector. Then test the voltage between the green wire and the black wire - at closed throttle, it should be less than 1V, a good reading would be right around .9V. Gradually open the throttle watching the voltage - the voltage should increase smoothly to around 4.8V at wide open throttle. If the voltage jumps around or is outside these ranges, the tps is likely bad (unless there is not 5V on the signal wire).
Old Aug 7, 2004 | 12:00 PM
mmendell's Avatar
mmendell
I'll give it a try! Thanks!
Old Aug 8, 2004 | 07:11 PM
mmendell's Avatar
mmendell
That took care of it! Now, a new oxygen sensor, and she'll be back on the road.
Thanks!
grldben
Aug 4, 2013 08:45 PM
Towmanjbo
1978 - 1996 Big Bronco
Jan 29, 2006 08:12 PM
capstan
Apr 14, 2005 07:31 PM
canneopae
25
Aug 10, 2003 08:56 PM
Hartnett
1997 - 2003 F150
Jul 22, 2003 09:02 PM
