Bad motor shake.
Old May 15, 2009 | 10:24 AM
wiredawg119's Avatar
wiredawg119
Bad motor shake.
I've tried searching, but everything I tried doesn't seem to work.
I have a 1983 F-150. Inline 6, Weber 2bbl carb, C6 trans. I don't drive the truck everyday, but do drive it 2-3 times a week.
Went to drive it one day. Pulled out of the driveway and it was shaking REAL bad. A few times around the block and it wouldn't stop. I parked it and started searching the site for help.
My search turned up fuel and vacuum as the 2 main causes. I cleaned up my vacuum lines a while ago so I know there are no holes in the hoses and I've been driving it since then, so I know that isn't it. Plus there is still good vacuum, I checked. I pulled the fuel line from the carb stuck it in a jug and cranked it. I get good fuel. I replaced the filter and mechanical pump just to make sure. Nothing.
It was running perfectly before this. The only thing I did recently was install an xm radio. I put in an aftermarket radio a long time ago and just spliced into that so I don't think that could have been it. I also installed a new vacuum module in the trans but have driven it since then. I had fluid in the line so I replaced the module and line. But other than that, I have done nothing to make it do this.
The shake is minimal at idle but still there. When you put it in gear it gets worse. You can give it throttle and it revs smooth. It doesn't seem to be missing. It just shakes. It's very scary to drive.
I'm at a loss, and need some help/advice.
Thanks in advance.
Old May 15, 2009 | 05:04 PM
murph77's Avatar
murph77
Complete the trifecta.
You have fuel, now check compression and spark.
Murph.
Old May 18, 2009 | 08:33 PM
trailtrekker702's Avatar
trailtrekker702
mine has a misfire and shakes more than id like it too, might be your problem too
Old May 25, 2009 | 10:15 AM
49fordpickumup's Avatar
49fordpickumup
This time of year moisture causes bad battery connections and worn spark plug wires to jump voltages across wires. Raise the hood at night and move the wire around to observe. Sometimes just cleaning the grease off the wires works. As the man said SPARK. chuck
45FMJoe
37
Jan 5, 2019 09:44 AM
90Ford73
36
Sep 10, 2017 02:08 AM
Calvin13
2015 - 2020 F150
15
Jul 29, 2016 11:55 AM
paintslinga2010
Dec 15, 2015 09:10 AM
areyou4real
Aerostar
26
Nov 9, 2015 05:19 PM
