Help ! 96 Explorer Idle problems
Old Jun 13, 2001 | 09:50 AM
Kage's Avatar
Kage
Hi.
I have a 96 Explorer 4.0,automatic, 61,000 miles. I have a problem that is driving me nuts! Here it is, The engine idles very rough when up to operating temp. on hot days. It runs fine in the cool evenings but not in the daytime!!! I can also feel it running rough at highway speeds in cruise control around 1800 rpm.I replaced the usual, plugs, wires, fuel filter, checked vacuume lines. The problem seemed to occur when I changed the plugs so I changed them again with autolite platinums, no improvement.Then I thought I may have damaged a wire, so I changed them, no improvement. The check engine light dosen't come on. So what can it be ? Any help would be greatly appreciated
Thanks
Ken
Old Jun 16, 2001 | 08:49 PM
CobraXP's Avatar
CobraXP
You may want to clean the EGR valve, throttle body, and ASC motor on the engine from any carbon build-up. The ASC motor is a metal cylindal with two bolts and 1 wiring harness on one end. I clean mine about every 15,000 when I change the oil, etc. It should help smooth the idle out some, but if you have a real rough idle, you have something else wrong...
Sounds simple, but also check to make sure all the wiring harnesses are plugged back in after you work on it. Have missed a plug before myself and know it can happen.
Good luck...
Old Sep 28, 2001 | 09:09 AM
PaulL's Avatar
PaulL
I have a similar problem, did this get resolved ?
Thanks,
Paul
Old Oct 10, 2001 | 12:30 PM
lrm's Avatar
lrm
I have the same problem on my 1991 Explorer 4.0l V6. When it kicks into overdrive and the RPMs are under 2000, the engine runs very rough. New plugs, new wires, new Ignition Module, new Fuel Pressure Regulator, and cleaned the MAss Air Flow Sensor.
One thing that helps is taking the battery power off for an hour or so to reset the computer. Then the tranny doesn't shift into overdrive at such a low RPM. Within an hour of driving it though that changes and same problem.
What does ASC mean and where is the ASC motor? The only components on the intake manifold are the Throttle position sensor and the air bypass valve.
There's an Air Charge Temeraure Sensor on the valve cover I haven't touched.
Old Oct 18, 2001 | 05:16 PM
lrm's Avatar
lrm
Found one of the culprits of my rough running engine. I pulled the spark plugs when the roughness was at it's worst and discovered the number 5 cylinder is getting oil in it somehow and fouling the plug. This URL pointed me to the problem. See the section submitted by Murray H. I also have some oil consumption, and this explained it.
http://www.glue.umd.edu/~singletn/web/pages/ping.html
Old Oct 18, 2001 | 08:41 PM
propellerhead's Avatar
propellerhead
Old Dec 24, 2015 | 11:19 PM
cpit1978's Avatar
cpit1978
I've been having similar problems with my 95! When I start it up for the first time it runs fine until it reaches operating temp. Then it stars to idle rough and if I let it sit and idle for a while then put it in drive or reverse it bogs down almost stalling! Sometimes it does stall. Starts right back up but if I'm not on the gas it almost want to stall again. After driving for a while I would have to let it sit for at least 5 or more hours to cool down. If I start it up any time sooner than that it barely wants to run sometimes stall right away after a very weak start. Over the past few months I've changed several parts; spark plugs, fuel filter, egr valve, egr dpfe, egr vacuum solenoid, air intake temp sensor, air filter, coil pack (last year), and still can't figure out what the problem is. Got an obd1 scanner (Innova 3145), ran it and came back with codes 114, 327 and 335 and that's after I changed all those parts. CLUELESS!!!
Old Dec 25, 2015 | 08:22 AM
shorod's Avatar
shorod
It's been awhile since I've looked over the ignition system diagrams for a 1995. The symptoms you describe are similar to what would happen when the ignition module was faulty on Fords around that era. The modules were mounted on the distributor and as they heated up, connections opened up (probably bad solder joints) and the engine would misfire and sometimes stall until the modules cooled enough for the joints to again make contact.
Does your 1995 have an ignition module?
-Rod
Old Dec 26, 2015 | 08:45 PM
redfury's Avatar
redfury
When was the last time the O2 sensors were replaced? Once the engine goes into closed loop operation, the O2 sensors come online. If they are faulty, they will cause poor idle/stalling and driveability issues.
Old Dec 27, 2015 | 12:20 AM
cpit1978's Avatar
cpit1978
Originally Posted by shorod
It's been awhile since I've looked over the ignition system diagrams for a 1995. The symptoms you describe are sismallmilar to what would happen when the ignition module was faulty on Fords around that era. The modules were mounted on the distributor and as they heated up, connections opened up (probably bad solder joints) and the engine would misfire and sometimes stall until the modules cooled enough for the joints to again make contact.
-Rod
My truck is distributorless, I have a coil pack. I took the throttle body off to clean it and noticed that the upper intake plenum had a small puddle of fuel inside it. I replaced the pressure regulator earlier this year.
Old Dec 27, 2015 | 12:23 AM
cpit1978's Avatar
cpit1978
Both o2 sensors were also replaced earlier this year
Old Dec 31, 2015 | 12:23 AM
cpit1978's Avatar
cpit1978
my ford almost stalled again today, still trying to figure out what's wrong! check engine light came on too so I put the obd1 scanner on it and came back with these codes. Any insight???
<table align="center" border="1" width="87%"><tbody><tr><td>
114
</td> <td>
(O,R)
</td> <td>
IAT sensor out of range – IAT
</td></tr></tbody></table>
335
</td> <td>
(O)
</td> <td>
EGR feedback signal is/was out of range – EVR or PFE
</td></tr></tbody></table><table align="center" border="1" width="87%"><tbody><tr><td>
327
</td> <td>
(O,R,M)
</td> <td>
EGR feedback signal is/was low – EVR or PFE
177
</td> <td>
(M)
</td> <td>
Oxygen sensor not switching – system was rich Left or Front HO2S – Fuel control
173
</td> <td>
(R,M)
</td> <td>
Oxygen sensor not switching – system is or was rich – Single, Right or Rear HO2S – Fuel control
113
</td> <td>
(O,M)
</td> <td>
IAT sensor is/was high or open – IAT
Old Dec 31, 2015 | 10:47 AM
redfury's Avatar
redfury
I'd look at the connection in the large harness plug in the engine bay under the air intake coming off the filter housing... See if you have a broken retaining clip that isn't holding it together tightly. Had that happen on a buddies 94. Can your scanner run the wiggle test?
Old Dec 31, 2015 | 09:00 PM
cpit1978's Avatar
cpit1978
I believe my scanner can run the wiggle test
Old Jan 2, 2016 | 06:01 PM
cpit1978's Avatar
cpit1978
I ended up changing the tps and pcv valve, drove it around for a while then ran the code reader again and got an 111 code. So hopefully the problems are solved! I will give it a few more runs though before I am completely sure that it's running correct. On the tps, the spring loaded part that connects to the throttle body was only spring loaded in one direction, the other direction just spent kinda freely, no resistance at all! Where as the new one was spring loaded in both directions. The pcv valve was crap also. Keep ya posted!
