Help ! 96 Explorer Idle problems
Old Jan 8, 2016 | 12:44 AM
cpit1978's Avatar
cpit1978
So the tps and pcv didn't solve the problem they just lessened it. What I did is pulled the vacuum hose off of the pressure regulator and eureka! Fuel started pouring out of the vacuum hose! I never suspected the pressure regulator to be the culprit because I just replaced it sometime last year. Long story short, the diaphragm collapsed and the regulator failed. Replaced it, only took about twenty minutes and all the problems went away. Reran the scanner on it and it passed every time. 111 code
Old Jan 8, 2016 | 12:47 AM
cpit1978's Avatar
cpit1978
No more bogging, rough idle's gone, no hesitation or stalling! starts up right away and runs with no issues at all every time no matter how long it runs.
Old Jan 8, 2016 | 06:51 AM
shorod's Avatar
shorod
Great, good find and thank you for following up with what you found!
-Rod
goldken51
1983 - 2012 Ranger & B-Series
Dec 13, 2017 12:50 PM
ken steele
Oct 31, 2017 12:38 PM
GummyMonster
Feb 22, 2016 12:47 PM
Ryleystr
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Feb 12, 2016 01:24 PM
NekSiwel
Jan 24, 2016 02:10 PM
