Another Valley Pan Question...
Old Aug 4, 2004 | 09:21 PM
53fatfndr's Avatar
53fatfndr
So I decided that I didn't want the Edelbrock Streetmaster intake that has been sitting on my 400 since the rebuild. This engine has not been started (fired up) as of yet. However, I'm putting on a Weiand intake instead (8010 manifold). My question is, since the engine has never ran, should I get a new valley pan and front and rear rubber seals, or can I just reuse the ones that were on there? Again, the engine has never been fired, it was just rebuilt with a different intake bolted on. I'm not sure, as I think since it was torqued down, I need a new pan, BUT, hopefully not.
Thanks.
Old Aug 4, 2004 | 09:35 PM
garypettengill's Avatar
garypettengill
Yep, torque = squished mating surfaces.
Old Aug 4, 2004 | 09:41 PM
mark a.'s Avatar
mark a.
I never run valley pans.
Old Aug 6, 2004 | 12:31 AM
jfinlen's Avatar
jfinlen
I just clean em up good and re seal them with a good non rtv type sealant. I've never had a problem yet.
Old Aug 7, 2004 | 06:02 PM
89bII4x2's Avatar
89bII4x2
fel-pro makes a good gasket for the intake that lets you get rid of the valley pan. I believe its a performance gasket so you will likely have to get it at a speed shop. It says not to install it on a stock motor mine had an edelbrock performer and i had no problems. The only thing is it comes with end seals for a clevlend but says it fits 351c/m and 400. The end seals will be to short but you just use silicone.
firegod75
Mar 6, 2015 01:03 AM
Dodge/Cummins
Mar 7, 2013 10:46 PM
54-66F100man
Dec 29, 2009 12:59 PM
lewislynn
13
Jun 7, 2007 02:33 PM
Voh
Dec 12, 2006 03:37 PM
