Sponsored by: Real Truck
tightening lug nuts
Old Aug 4, 2004 | 06:30 PM
Gwilkrrs's Avatar
Gwilkrrs
tightening lug nuts
im replacing front rotors soon and want to make sure that im not hurting them be installing wheels wrong. i now see everyone is using torque wrenches. i always ran the lugs on 1 at a time to tight in aq star pattern then around in a circle to finish.
what is the proper way?
i dont even own a torque wrench. are they expensive? where to buy?
thanks!
Old Aug 4, 2004 | 06:32 PM
jdadamsjr's Avatar
jdadamsjr
They can be had relatively inexpensively...
but I might give u a heads up that it is pretty important to stop rotor warping to torque these equally in a star pattern and evenly to about 145 to 155
Old Aug 4, 2004 | 06:39 PM
Gwilkrrs's Avatar
Gwilkrrs
do you do one lug to 145 then the next in a star, or do you gradually get to 145 in a star?
Old Aug 4, 2004 | 06:44 PM
boxcar1974's Avatar
boxcar1974
Increments.....tighten to about 90 ftlbs and then to 145
Old Aug 5, 2004 | 11:45 AM
smcallis's Avatar
smcallis
Wait...our lugs are spec'd to 145 ft lb? I just did mine only to a hundred. Why such a high torque spec? Expecially with 8 lugs...
Old Aug 5, 2004 | 12:10 PM
cwb's Avatar
cwb
$59 at Home despot. And it's 150 ft lb's.
Old Aug 5, 2004 | 12:25 PM
believer45's Avatar
believer45
1995 Ford service manual shows torque on eight and 10 lug F250-350-450 trucks with 9/16 - 18 threaded studs at 140 lb-ft. I don't imagine 10 lbs either way is a big deal.
My own method is to torque all to 50 lb-ft in a star pattern then 100 lb-ft again in a star pattern then to 140 lb-ft in a star pattern then go around the wheel to double check 140 lb-ft.
Dave / Believer45
Old Aug 5, 2004 | 12:29 PM
smcallis's Avatar
smcallis
Yes stage torquing is a good thing to do. Also be sure to recheck after a couple trips around the block..
Old Mar 14, 2005 | 02:42 PM
rhenriksen's Avatar
rhenriksen
Scary thing is, I have friend's F250 on loan for the weekend. I rotated his tires for him, and tightened them down to 150#. Then, being paranoid, called the local dealer's service dept and asked them what the correct torque was for lug nuts on an F250. Guess what they told me?
100#!
I decided to go with the owner's manual over the dealer. Sheesh.
Old Mar 14, 2005 | 06:18 PM
believer45's Avatar
believer45
Originally Posted by rhenriksen
...called the local dealer's service dept and asked them what the correct torque was for lug nuts on an F250. Guess what they told me?
100#!
ALWAYS a good idea to go with what you can see over what the dealerships tell you unless it is a dealership you trust. I have two near me (one Navistar truck dealer and one Ford / Sterling truck dealer) that work on nothing smaller than the PowerStroke and do very little of that but they have a couple guys at each who really know their stuff. Plus they are truck people.
Maybe your dealership was looking up the torque output of a ricer for someone else and got the numbers mixed?
MY LUGNUTS TAKE MORE TORQUE THAN YOUR CIVIC PUTS OUT
Dave / Believer45
Old Mar 14, 2005 | 08:27 PM
texex's Avatar
texex
Haynes manual for 99-02 f250 & 350 states:
2000 and earlier models, 148 ft lbs
2001 and later models, 155 ft lbs
Definitely want to torque incrementally and star pattern
Good luck
2000 F250 Lariat, SB, CC, V10
Old Mar 14, 2005 | 08:48 PM
99f350sd's Avatar
99f350sd
You guys make a big stink about torque and the lug nuts. On the super duty the design of the rotor and hub make it impossible to warp the rotors with loose or differently torqued nuts. some other designs where the studs are in the body of the rotor are definetly affected by different torques. All the wheel does is squeeze the thin rotor metal between it and the hub. All I'm saying is that its not that important on the Super Duty trucks..Now 2wd trucks with a rotor with the studs in it and you can warp that all to heck. The automotive industry gives those torques so the nuts will never fall off.
Old Mar 14, 2005 | 10:39 PM
texex's Avatar
texex
Man, if I knew everything, I wouldn't waste time in this forum ..
Old Mar 15, 2005 | 07:59 AM
believer45's Avatar
believer45
Had an issue a few years back with overtorquing cracking the cast hubs on a series of semis. Drum brakes so it was not a brake rotor issue.
Overtorquing cracks wheels, breaks studs.
Undertorquing lets wheels "work" and can oval out the tapered stud holes, also can cause excessive runout.
But what do I know - 31 years in trucking, over half in maintenance as a supervisor, trainer, manager and occasional wrench turner.
Dave / Believer45
Old Mar 15, 2005 | 08:25 AM
jdadamsjr's Avatar
jdadamsjr
99f350sd,
MANY of the newer sd's and excursion have had issues with rotor warping and MANY have come to the conclusion that improper torque setting is the problem....
