Width of rear of cab, measurement taken from inside to inside of pillar, and a same level as seat base (top) which is 2" below the bottom of the square knockout hole on either door pillar: 50 1/4 "
Hope this helps! AL
AL is the cabs of '40-'47 the same width at the front of the cab as it is at the rear of it? Could you measure at the front of the door openning across to see if it is the same as at the back and also check the width at the dash height and at the roof height please it would be greatly apperciated. Thanks
The front of the 40 is pinched in the front of the door area and wider to the rear. I'll give you those measurements later today. Also, you should also have the cab squared, measure diagonally from, say top hinge hole across to body line on the oposite side. This will properly align the body especially when you are replacing floors pans.
The hardest thing to find around here is someone to give you a measurement! WHY IS THAT?????
