lower rear door pillar problem
Old Aug 25, 2015 | 03:24 PM
the body's Avatar
the body
i have a 1984 std cab i need to change the full rocker,cab corner,side floor pan,and the outside lower rear door pillar (all left side)
the problem is on all website they ship me a rocker assembly with the door post but they fit only 87 and newer. The front pillar is the same but not the rear one.
did somebody have other website then (keystone,lmctruck,npd,rockauto)
Old Aug 25, 2015 | 03:45 PM
Franklin2's Avatar
Franklin2
What does the 87-up piece look like? Is it like this piece?
1980-98 Ford Pickup/Bronco OEM Rocker Panel w/Door Post, Driver Side
They also sell this piece now that must repair the rear corner/floor area.
1980-98 Ford Pickup/Bronco Rear Pillar, Standard Cab Only, Driver Side
Old Aug 25, 2015 | 07:36 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I use Tabco.
They have the B-pillar corner for 80-86 trucks.
https://tabcoparts.com/pickup-trucks/ford/pickup-bronco-1980-1998.html
Old Aug 26, 2015 | 12:01 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Old Aug 28, 2015 | 10:47 AM
the body's Avatar
the body
franklin2 yeah the 1987 is like that but not the 86 one ... the rocker on a 1986 is not include with the door post there is a flat full rocker and the door post are welded on like the picture of numberdummy
Old Aug 28, 2015 | 10:51 AM
the body's Avatar
the body
Originally Posted by ArdWrknTrk
I use Tabco.
https://tabcoparts.com/pickup-trucks...1980-1998.html
that one is the interior one the hole right there I think is for the bolt that hold the belt
Old Aug 28, 2015 | 11:06 AM
the body's Avatar
the body
number dummy thank you for the picture so i need the lower part of the 28160 did somebody have nerver seen this anywhere ?
Old Aug 28, 2015 | 12:16 PM
Franklin2's Avatar
Franklin2
The one in the link is for a 80-98.
Old Aug 28, 2015 | 02:30 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I've never seen the rocker with A or b pillars attached unless it was just the glue on 'slipper' that some people use to hide rot without fixing it.
The major difference with '87 B pillar sheetmetal is the plateau and hole for the seatbelt retractor button down in the corner.
Seat belts all attach to a plate and nut *on the bottom* through the inside rocker.
Old Aug 28, 2015 | 02:37 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Tabco 60142 L or R is the bottom of the inner B-pillar
I know they fit because I've used them.
Old Aug 29, 2015 | 12:20 PM
the body's Avatar
the body
yeah this is the problem of all the website that sell parts. it don't fit on 1986 and older
Old Aug 29, 2015 | 12:21 PM
the body's Avatar
the body
yeah the problem is i need the outside one
Old Aug 29, 2015 | 12:36 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
28160 is the INNER panel.
if that's not the one you need, get the cab corner instead.
If you don't believe any of us that have used these parts, go down to the paint and bodywork forum in the misc. category.
Ask some of the body guys down there.
Or call Tabco direct.
They MAKE the panels that they sell right there.
Old Aug 29, 2015 | 10:40 PM
thisismary's Avatar
thisismary
Ask some of the body guys down there. (Shortened)
I bought Tabco panels - total newbie - to truck restoration they fit.
AND I shot the the replacement panels with my ultrasonic thickness tester - as thick or better than the body steel on my truck.
c11802362
Oct 9, 2017 06:29 PM
chad77
Nov 26, 2015 06:31 AM
Cougstruck
Jul 1, 2013 02:54 PM
Supercab
Oct 31, 2012 05:22 AM
irondragon79
Nov 22, 2002 05:33 PM
