1978 - 1996 Big Bronco
front/rear differentials 1990 EB edition
Old Aug 4, 2004 | 12:57 PM
brad76f250's Avatar
brad76f250
just wondering what ratio the front and rear are, or how i can find out.
i now its a dana 44 in the front. and probly that in the rear.
Old Aug 4, 2004 | 03:44 PM
Kemicalburns's Avatar
Kemicalburns
stock is 3.54 up front and 3.55 rear. the rear axle is a 8.8
there should be a little tag on each diff cover if not the vin code in the door jam will also give info. just post what you read here
Old Aug 4, 2004 | 03:45 PM
InkDawg's Avatar
InkDawg
I'm guessin that the 44 is in the front and you have an 8.8 in the rear. Look on the rear and see if it has a speed sensor plug on the front side of it. If it does then its more then likely an 8.8 because a 9" which older broncos were does not have this. Also the 9" comes apart from the front where the 8.8 has bolts on the rear side. But I'd bet money you dont have a 44 in the rear unless someone else put it in. And the gears would be around 3.55.
Old Aug 4, 2004 | 04:07 PM
brad76f250's Avatar
brad76f250
ok cool thanks. gonna check on that.
how hard would it be to put a 44 in the rear?
Old Aug 4, 2004 | 04:08 PM
Kemicalburns
why would you want to. doesnt make sense. explain what your goals are and we can help better
Old Aug 4, 2004 | 04:09 PM
brad76f250's Avatar
brad76f250
i dunno... just wondering... no reason
Old Aug 4, 2004 | 04:24 PM
Kemicalburns
first it would have to be custom made. you would be better off beefin up the 8.8, swap in a 9" or going to a sterling 10.25 1ton axle. those are your choices
Old Aug 4, 2004 | 07:01 PM
brad76f250's Avatar
brad76f250
ah, ok. thats what i was getting at... somthing a little more beefy.
Old Aug 4, 2004 | 07:58 PM
andym's Avatar
andym
Why do you need something stronger than the 8.8? Unless you're putting huge tires on, or beating the crap out of it, you're fine with the 8.8.
