1978 - 1996 Big Bronco
ignition problems
Old Jul 27, 2004 | 11:50 AM
beastybronco's Avatar
beastybronco
ignition problems
i just replaced the starter and starter relay and seems to be havin even more troubles
randomly the starter spins with no contact to the fly wheel or sometimes the starter gets stuck on where it wont disengage
very weird it only happens once in a blue moon then i will give it a minute and maybe disconnect the battery for a minute or two and then it starts and runs fine
i think i need new a new ignition something but i have no experience with this can someone tell me what to replace first? and cost?
Old Jul 27, 2004 | 12:02 PM
oledog's Avatar
oledog
I don't what year but I'm pretty sure this has nothing to do with your ignition.
Starter or starter gear could be wrong or too short, flywheel could be missing teeth or bent. Maybe the starter bolts got loose?
No way is it the ignition
OleDog
Old Jul 27, 2004 | 01:06 PM
beastybronco
its an 88' i dont believe the flywheel has any missing teeth because when the starter does mess up it doesnt grind or any such thing it just spins freely also it gets good grip because it starts almost all of the time just randomly it doesnt seem to go in far enough or gets stuck in
it could be the soleniod on the starter but i figured since it was new it had to be something else
Old Jul 27, 2004 | 02:14 PM
mustangman65_79's Avatar
mustangman65_79
sounds like u got a bad starter. The bendex is whatmakes the starter move in and out, and it sounds like that is bad.
IS it a new starter, or a rebuilt?
Old Jul 27, 2004 | 02:27 PM
Zoomie331r's Avatar
Zoomie331r
Had that problem about a yr back with My 87F150 the armature was shortin out took it back to parts house an they tested it a couple of different times replaced starter an havnt had prob since
Old Jul 27, 2004 | 02:48 PM
beastybronco
it is rebuilt ... i knew that would come back to bite me but i could make myself pay the extra $50
i will be taking it off and taking it back to Autozone today ... it has a 1yr warrenty but i lost my reciept!!!
Old Jul 27, 2004 | 02:58 PM
mustangman65_79
If u gave autozone your phone # they will have it on their comp.
I spent $90 for my brand new one, it was smaller and spins faster, I like it. #yr warrenty from autozone.
Old Jul 27, 2004 | 03:33 PM
beastybronco
also what if it stays on when u turn the key off that would mean solenoid right not starter?
sorry i wasnt clearer but that is what i meant by saying it would not dissengage
Old Jul 28, 2004 | 08:37 AM
mustangman65_79
I had a starter do that once and it was the starter that was bad. SOmething about the starter pulling the power through the solenoid and made the solenoid stick. I also for part of the problem was due to a bad ground.
Old Jul 28, 2004 | 08:41 AM
oledog's Avatar
oledog
If you mean it starts and the starter is still engaged(spinning) then I'd go with mastangmans answer about the bendix spring. BTW shut if off quick if that happens.
I've heard of a soleniod not engaging but I've never heard of it not disengageing, maybe somebody else knows.
Old Jul 28, 2004 | 09:20 AM
beastybronco
well i have never been around the truck when it does this with me it has always been an angel but when someone else tries to use it she starts acting up
as the story goes the truck started and the starter would not dissengage and then even with the key off the starter kept trying to start the truck until the battery went dead
thats y i think it could be the solenoid because how else would power still be supplied to the starter with the key off?
Old Jul 28, 2004 | 09:22 AM
mustangman65_79
Read up one
beastybronco
i think i will probably replace both as a defiante fix the starter is under warrenty (though i may upgrade to a new one) and the relay is like $12
just to make sure i dont get stranded somewhere or destroy my flywheel or something
Old Jul 28, 2004 | 09:42 AM
mustangman65_79
Crap I worte a nice long message, and the comp deleted it. So to make it short, make sure u replace the starter, and replace the solenoid if u want to
Old Aug 4, 2004 | 07:25 PM
beastybronco
well i replaced the starter brand new not reman. and guess what the starter just locked on even when i turned the key off it still tried to start until the battery died
so it cant be that i didnt replace the solenoid though so i guess i'll do that and then tear my ignition switch out
any help i need to get this going very soon i will be buming rides to work until then
