Help with a Stalling 5.0L
5.0L having trouble "staying lit" when hot
I dropped a SEFI, 5.0L from an '86 Lincoln MkVII into my '53 Mercury M1oo.
It starts no problem ... however, once it's warmed up she's takiin to stalling... particular in intersections and when my 12 year old daughter is on board! [Too much xx]
I've replaced the TFI twice! , and found a poor conncetion as well
and repaired them but the truck is still stalling out when I, come to a stop...not consistently, just annoyingly frequent!
I've been camping with the family the past 4 days in the Muskokas.
I was dissappointed I couldn't take the truck but it just isn't dependable enough yet for family travel
ANyways, I'm going ou to the garage later tonight or tomorrow and wondered if any of you gearheads had any other suggestions or a protocol for tracking down this nasty varmit of a problem
LMK
GW
Any suggestions?
If all else fails just go ahead and replace the O2 sensors (you should have two) then try running for short distances (at operatiing temp) with one of the sensors electronically disconnected (MAP, temp, throttle position, canister purge, EGR, and air injection relays). I did this and found a bad connection on the temp sensor... if you pick the errant sensor you should notice little change in performance... if you pick an operable sensor... the engine will be noticeably off. The EEC IV has several "modes" such as Cold Start, Hot Start, No Start, normal cruise, etc... It also has a "get me home " mode that will keep the car running if ALL the sensors are out of whack.
I've tried all these... I don't claim any expert status, so please excuse any technical errors. I have been running my '69 with the 5.0L for 3 years and am mostly satisfied with it.
By the way, mine is non-HO but has the HO firing order... does yours?
Good Luck
CT
