1978 - 1996 Big Bronco
Bad idle when engine warms up?
Old Jun 15, 2003 | 09:27 PM
gvolosh1's Avatar
gvolosh1
Hi,
I have a 1990 Bronco with 5.0L.
I have a problem with stalling and very poor idle when the engine is hot and is turned off (for a few minutes) and then restarted.
It stalls and does not want to idle. I must give it some gas and rev it up for a few seconds before the idle stabilizes. If I do not gas it on start up, the engine just stalls.
Any suggestions where I may have a problem?
Thank you in advance,
George
gvolosh1@san.rr.com
Old Jun 15, 2003 | 10:49 PM
steve83's Avatar
steve83
Pull the codes and put a fuel pressure gauge on the test port on the fuel rail. I suspect your fuel pump is dying.
Old Jun 16, 2003 | 06:01 PM
Memento's Avatar
Memento
Also check the EGR solenoid valve. if your still pulling vacuum through it after the engine is warmed up. you will get a very rich ruff idle.
Old Jun 16, 2003 | 06:21 PM
TexasBronco's Avatar
TexasBronco
Check and clean the idle air control valve.
If no joy, w/ any of above suggestions, check the timing is on spec. If that's no help try moving the timing to retarded setting. That's what worked for me, but don't know why.
good luck
Old Jun 18, 2003 | 07:06 PM
Brents2's Avatar
Brents2
Had same problem. Changed IAC still no good. Found out Ford has a part to fix idle stalls and surges. Alot of Dealers dont even know they stock it. Its just a flat machined plate(spacer) with allen screw adjustments to let more air go around the throttle body in order to maintain proper idle. It fits between the IAC and
throttle body.
gvolosh1
May 4, 2003 08:39 PM
gvolosh1
May 2, 2003 09:55 PM
gvolosh1
Apr 9, 2003 02:53 AM
gvolosh1
Nov 17, 2002 11:45 AM
Big Red F250 SD
Oct 30, 2002 12:07 AM
