Carburater problems
Old Aug 2, 2004 | 11:36 PM
awsomefords's Avatar
awsomefords
Question Carburater problems
Hello Everyone,
I have a question about this new truck I got a while ago its got a 302 engine in it. My problem is the idle... the carburater is a 4 barrel im pretty sure..It has always had problems with the idle like it taking forever for it to go down when I start it up. But I was changing the valve cover gaskets cause they were leaking oil and I had to unhook some hoses what I think was vacume hose's to get into the covers and I was bumping into the carburater cause it was a very tight space but I got the new gaskets and all that worked out but when I started the car up it idled kinda high then I pressed the gas and it just slowly droped till the engine shut off. I tryed it again and the same problem. Could one of the vacume hose's being out cause this problem? Or is it somthing else I hope I didnt mess up anything but I marked all the hoses as I took them out. There was one hose that was old and dry rotted so it broke which im getting a new one but it just went to the brake booster I think its called. Is there anything I can adjust for the idle? Or is that not the problem? I can keep the car runing as long as I hold the gas pedal down alittle. Your help with this question would be greatly apreciated thanks.
Old Aug 3, 2004 | 12:01 AM
pfogle's Avatar
pfogle
If you didn;t hook the hoses back up then you probably have a very serious vacuum leak. DO NOT run the engine that way, you can and will damage the enigne.
Thipdar
May 21, 2016 02:02 AM
masonandeers
19
Jan 5, 2016 03:25 PM
ollirrap
Dec 18, 2012 09:38 AM
awsomefords
Feb 17, 2005 07:36 PM
gearshift101
Jan 31, 2004 12:01 PM
