Blown Turbo...HELP~
Old Aug 2, 2004 | 06:28 PM
majorpecs's Avatar
majorpecs
Blown Turbo...HELP~
Well I just got a call from my buddy who has been looking at my truck. The turbo is blown. He said the bearings went, then the extra movement that allowed caused the fins to get jacked up on the housing. He said I have to get a new one and dealer cost is about $750...he found one at a junkyard for $400 with no guarantee. Is there some kind of re-build kit or something to fix my turbo? I know I can get a new compressor wheel, but I don't know about the bearings and stuff...if anyone can help me out I'd appreciate. Oh yeah, the reason I'm posting is that I am STRAPPED for cash at the momnent....in a bad way.
Old Aug 2, 2004 | 06:41 PM
BagStroke's Avatar
BagStroke
Look on ebay!! type in Powerstroke 7.3....
http://cgi.ebay.com/ebaymotors/ws/eB...category=33742
Old Aug 2, 2004 | 06:51 PM
majorpecs's Avatar
majorpecs
Thanks Bagstroke...does anyone know for sure if this is the part number for my truck. 2000 F250 4x4 7.3L
PART NUMBER IS 1831457C91, SERIAL # CLL39403
Thanks in advance!!
Old Aug 2, 2004 | 06:57 PM
BagStroke's Avatar
BagStroke
Thanks in advance!!
I donno what that number is?? is it your turbo number? these turbos will work for you!!!!!!!
Old Aug 2, 2004 | 07:12 PM
BagStroke's Avatar
BagStroke
Old Aug 2, 2004 | 08:50 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Thanks in advance!!
The turbo from any 99.5-2003 7.3 PSD is exactly the same as yours.
Since your wheel has been into the housing I would not bother with rebuilding it. You're not going to get a gaurentee on any used turbo, but if you buy the cheapie used one and put a rebuild kit in it you will at least have some peace of mind.
I posted the rebuild kit part # in THIS THREAD
Old Aug 3, 2004 | 07:18 AM
majorpecs's Avatar
majorpecs
Thanks for all your help guys....Cookie and Bagstroke you guys ROCK!
Old Aug 3, 2004 | 07:19 AM
majorpecs's Avatar
majorpecs
Cookie, what if I bought a new compressor wheel along with the rebuild kit? That would still be a cheaper option I believe....
Old Aug 3, 2004 | 08:02 AM
majorpecs's Avatar
majorpecs
Will this turbo work on my 2000 7.3l?
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Kwikkordead's Avatar
Kwikkordead
I agree with Cookie - don't use the old housing. The compressor wheel would have gouged the surface on the inside, ruining it. So your cheaper option that you mention is actually not an option at all.
Old Aug 3, 2004 | 08:09 AM
BagStroke's Avatar
BagStroke
no I dont think so..........
Old Aug 3, 2004 | 08:56 AM
cookie88's Avatar
cookie88
FTE Emeritus
Nope. This one is the one that would fit yours.
Old Aug 3, 2004 | 09:27 AM
BagStroke's Avatar
BagStroke
Bump to cookie!! yup that one..
Old Aug 3, 2004 | 10:18 AM
majorpecs's Avatar
majorpecs
Thanks Cookie...
Old Aug 3, 2004 | 06:55 PM
cookie88's Avatar
cookie88
FTE Emeritus
Thanks Cookie...
No problem. You can still rebuild your turbo if you would prefer too, but the damaged housing would need to be replaced and since the exhaust wheel is welded to the shaft, you would need to replace that too (the turbine shaft may have been damaged when the wheel contacted the housing).
HERE is a good rebuild article for a TP-38. The procedure will be pretty much the same for the GTP-38 on your truck.
