Air Filter Minder gauge
Old Aug 2, 2004 | 04:09 PM
jdadamsjr's Avatar
jdadamsjr
Does anyone have a link with info how to read this air filter minder ?
Mine hasn't moved in 32K miles (except when the mechanic broke it off and I had to have it replaced)
truck still runs fine (read fast!) and no warning lite on the dash or anything....
Old Aug 2, 2004 | 04:16 PM
Daryl Hunter's Avatar
Daryl Hunter
Mine at 24 k miles has moved a smidge. I've done some off roading with it and there's a bit of dust that's been kicked up over the last year near my office from contstruction in the area. Other than that, the air here is pretty clear.
Old Aug 2, 2004 | 04:53 PM
AlaskaPowerStroke's Avatar
AlaskaPowerStroke
We had a lot of smoke and particles (<1,000ppm) in the area so decided to change air filter at 30,000. Wasn't too bad, but could tell the difference between the new and old filter (color). Still have not figured out how to reset the filterminder. Ours didn't move much at all not really sure how accurate they are.
Old Aug 2, 2004 | 05:23 PM
04F250CC60's Avatar
04F250CC60
The filter minder is reset by depressing the yellow rubber button. It works off of vaccum. As the filter catches more debris and slows the flow of air the yellow bobber inside moves out (closer to filter housing). My 550 is constantly on land development jobsites so I've seen the filter minder pretrude to about the 3/4 mark and still no light. Just to check if it was operable I pulled the bobber to the max point and low and behold the dash light came on. For me it is not the filter minder that tells me that the filter is becoming clogged, it's the increse of black smoke from the lack of air.
Old Aug 2, 2004 | 10:27 PM
jdadamsjr's Avatar
jdadamsjr
I have no black smoke - even witht he predator and lot's of full throttle starts....
And don;t see ANY movement of the minder...
is it a "pin" that goes CLOSER to the air filter when it is used ???
I can even read the stupid gauge marks it's so unintelligible
IABill
May 12, 2012 08:22 PM
snakedoc
Nov 28, 2011 11:00 PM
R-T0r21on
6.4L Power Stroke Diesel
Jan 19, 2011 03:25 PM
dyna
Dec 20, 2008 02:17 PM
superv10
Aug 30, 2007 05:12 AM
