need some engine mod info....
the mods i know i'll add as affordable are as follows:
Holley 390 4bbl
EFI manifolds
MSD Duraspark II ignition system
ZF 5 spd transmission
9" Rear end
solid axle front end
the mods i want, but don't know enough about are as follows:
Offy intake
---i don't know much about the various types of intakes that offenhauser offers...could somebody explain what some of the various intakes are and how they affect performance???
exhaust
---i'm thinking dual 2 1/4" pipes from the manifolds through either dual Flowmaster 40 series or dual glasspacks
---with the glasspacks, i think i'll go with 24" packs, as i currently have a single 30" pack w/ 2 1/4" pipe, and i want a bit louder....my ? is will the 24" packs give me more rumble at idle and accelleration?
cam
---i don't know how various cam durations will affect various aspects of engine performance...if somebody could explain how the cam duration affects horsepower and torque, it would be much appreciated
valvetrain
---i don't know what all is available for options in this area...i read a posting on chevy parts for the 300-6
---"The head, likewise, can be modified. Port, polish, mate, bigger valves (small block chevy valves - 1.94 intakes & 1.60 exhaust valves can be installed). 7/16" Screw in rocker studs can allow higher ratio (big block chevy 1.75) rockers. Again - no difference here - you can treat it like ANY performance head."
---my question on this is, how would these modifications affect performance, fuel, etc.???
any help or suggestions would be very much appreciated...thank you...
MontanaFord
