Explorer - high idle, throttle sticks
Old Dec 22, 2001 | 06:06 PM
fish_r_1's Avatar
fish_r_1
Hi all.
1991 Explorer 2wd 5 spd manual trans 174000 mi. Engine idles real fast when started, then drops to 900 rpm, cycles through this 3 or so times each startup esp when cold. Also, when shifting gears the throttle sticks at around 2000-2500 rpm after gas pedal is released and stays at that rpm for about 10 secs, then drops to normal idle.
Any ideas where to start? Thanks for the input.
Old Dec 23, 2001 | 09:45 AM
fish_r_1's Avatar
fish_r_1
Disconnected negative post at battery so ROM could reset and chip would "relearn" the correct idle.
Took apart the idle air bypass, disconnected the motor from the valve part - cleaned the piston and sleeve on the servo, really gunked up with carbon and crap.
Butterfly valve on the intake manifold was really loaded with carbon and gunk. Cleaned all that off, lubricated the external linkage.
Put it all back together, reconnected battery and fired it right up. Idles where it should, after the chip scanned for correct idle.
:-X12
Old Dec 23, 2001 | 11:27 PM
luxury 4x4's Avatar
luxury 4x4
litleguy
Jun 5, 2010 10:25 PM
1984 f-250
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Oct 29, 2005 01:08 AM
jeffwecker
Jul 22, 2005 04:37 PM
thelonerangerxlt
Oct 9, 2003 07:54 PM
Mary_Kate_Olsen
1978 - 1996 Big Bronco
Oct 5, 2003 10:29 PM
