'85 Econoline Starter Relay
Old Aug 1, 2004 | 02:52 PM
Econo-canada's Avatar
Econo-canada
I've swapped the electronics from an '85 E-150 into a '79 E-250. I have power to everything, all accessories works, but it won't start. Won't even click. On the starter relay, the two main posts are connected to the correct items (battery / starter), and the red/blue ignition wire is hooked up. What I'm wondering is... there is another connection point, which from all my searching looks like a ground connection, but it is not hooked up to anyhting. Would I be safe to hook this up to ground and try to start it again? Or have I missed something with the swap.
Thanks for the help....
Old Aug 1, 2004 | 04:26 PM
87 XLT's Avatar
87 XLT
Yours might be different, but the wiring diagram for my 87 only shows that the starter relay is grounded thru its mounting screws. If yours is wired the same as mine when you turn the key to start you should see 12 volts on the red/light blue from the ignition switch. Only other wires are the fuse links/starter/battery cable.
Old Aug 1, 2004 | 08:56 PM
Econo-canada
I think i may have found the problem. The neutral start switch is wired differntly on the two years, so I'll replace that and see what happens. Hope it's something simple
Old Aug 1, 2004 | 10:20 PM
87 XLT's Avatar
87 XLT
Sounds like your on the right track, good luck with it.
Old Aug 1, 2004 | 10:37 PM
Econo-canada
That was it. There's a quick connect that has four wires, the neutral start switch being part of it (back up lights the other). Same quick connect for the 85 as the 79, but on the '79 the wires are rotated one space clockwise. Re spliced 'em in the right order, and she fired up.
Thanks for the info on the starter relay. The stock '79 incorporates the "I" terminal, where as the '85, like your '87, doesn't.
Cheers!
Old Aug 1, 2004 | 10:47 PM
87 XLT's Avatar
87 XLT
And thank you for the update, glad to hear you got it figured out.
jasindude1
1978 - 1996 Big Bronco
Feb 26, 2017 04:05 PM
waystro
Dec 16, 2015 04:52 PM
frustrated mechanic
2004 - 2008 F150
19
Jun 10, 2015 04:15 AM
Plankton
May 13, 2015 04:05 PM
TheRumpledOne
1983 - 2012 Ranger & B-Series
Feb 4, 2014 08:59 PM
