Need HO alternator
Old Aug 1, 2004 | 12:25 AM
hoxiii's Avatar
hoxiii
Need HO alternator
What is the highest output OEM Ford alternator and what application did it come in? I'm lookng to upgrade for a winch and dual battery setup and need a bit more juice than my current 65A is squeezing out.
How about a GM single wire conversion? I know they came in the 200A flavor, anyone done it? What about the GM 150? I'm just looking for the most power I can for a "reasonable" price.
Justin
Old Aug 1, 2004 | 02:20 AM
joners's Avatar
joners
You can put a 3G Ford alternator in, they put out 130 Amps.
Old Aug 1, 2004 | 07:01 AM
Bob Ayers's Avatar
Bob Ayers
I have no experience with them, but you can try this URL for a 200A alternator:
www.mralternator.com
I would go this route, before even thinking about a GM product!!!!
Old Aug 7, 2004 | 05:26 PM
Chuky66's Avatar
Chuky66
I got a 93 Taurus 130 anp 3G from a bone yard for 30 bucks and am putting new brushes in it for 7 bucks. Same basic bolt pattern as mine on my 86 F250 with 460 in it. Might require a bit of spacing and will require some rewiring, but nothing major.
Chuck
Old Aug 11, 2004 | 02:31 PM
lmadore's Avatar
lmadore
PA Performance sells 3G alternators up to 200 or 250 amps.
Mandatory to upgrade the harness with on 130A or more.
Old Aug 24, 2004 | 07:15 AM
Bart99GT's Avatar
Bart99GT
I might add that you only need to upgrade the wiring harness, specifically the cable running to the battery, if you've drastically increased the load on the system. Simply installing a higher output alternator doesn't require larger guage cable by default.
Old Aug 24, 2004 | 02:16 PM
Franklin2's Avatar
Franklin2
Well, I hope someone would be installing a higher amp alternator for a reason, so I think it would be good practice to upgrade the output wire size a little bit.
Old Aug 24, 2004 | 05:56 PM
hoxiii's Avatar
hoxiii
Project is on hold for now(school), but it looks like i'm going to be doing the 130 3G swap, my guess is sometime around thatnksgiving. There will definitely be an icreased load on teh alternator so i'm probbaly going to run at least a 4GA to the battery.
Justin
hoxiii
Sep 23, 2007 11:28 PM
hoxiii
Oct 4, 2004 07:29 AM
hoxiii
Offroad & 4x4
19
Aug 3, 2004 05:52 AM
Justin03PSD
Oct 23, 2002 07:46 PM
