By-passing the ignition switch
Old Jul 31, 2004 | 07:33 PM
MS99k's Avatar
MS99k
He guys, i've accuired a 74 Ford F-100 with a 302 in it, but the wiring harness is hacked up, i was wondering whats the least necessary wiring require to atleast turn it over with a screwdriver at the solinoid just to see how strong it runs, what all needs to be wired up.
Thanks,
Mike
Old Jul 31, 2004 | 07:48 PM
DT 466Man's Avatar
DT 466Man
power to the coil power to the ignition if electronic
and 12V to the signal wire on the solenoid
Old Jul 31, 2004 | 07:55 PM
Mil1ion's Avatar
Mil1ion
How do we know you aren't a truck thief ?
Old Aug 1, 2004 | 03:51 PM
MS99k's Avatar
MS99k
www.misterhits.com/truckpics/ Check out the wirining on this baby u will understand i hope.
EDIT:
DT, so a power wire in the coil, a power wire to the solenoid, and a wire to the ignition and i can use a screwdriver on the solenoid and it should start?
Old Aug 1, 2004 | 05:16 PM
DT 466Man's Avatar
DT 466Man
yes if the ignition has power and you crank it over it should start unless it has alot of electronic do dads.
EDIT:
it looks like you have a fairly clean motor
try giving it 12V to the + side of the coil make sure it has a good ground and give it power to the solonoid it should start
how long has it been siting? is the fuel good?
Edit/Delete Message
Old Aug 1, 2004 | 06:29 PM
Mil1ion's Avatar
Mil1ion
Attention all users.
FTE allows 60 minutes for a user to go back and edit (make changes) to their own posts.
It is more beneficial to FTE to do this,rather than clicking *Post Reply* again just to add 1 or 2 kb of text instead of re-loading the whole user's profile again.
Please help us.
Old Aug 1, 2004 | 08:01 PM
DT 466Man's Avatar
DT 466Man
ya'll went and made alot of changes to this thread i couldn't find it
good luck with the truck
keep us posted on your progress
Old Aug 2, 2004 | 07:05 PM
monckywrench's Avatar
monckywrench
http://home.cfl.rr.com/mustangsix/Engine/duraspark.htm
http://www.mustangsteve.com/conversion.html
"Generic" Duraspark diagrams.
I actually have a seperate Duraspark system made from leftover parts I use for testing. You can just grab the parts and harness sections from a donor car or truck. and have a stand-alone harness. Even if the rest of the truck wiring it fried the truck will be driveable.
Old Aug 2, 2004 | 08:47 PM
MS99k's Avatar
MS99k
the fuels good, its just that harness lol i'll try this tomorrow
Old Aug 3, 2004 | 08:48 AM
SoFla David's Avatar
SoFla David
you know it's gonna be bad when you open the hood and see Wirenuts!
