Correct Differential Oil?
Old Jul 30, 2004 | 03:59 PM
Black Ranger's Avatar
Black Ranger
I'm about to change my differential fluid in my 1994 4.0L ranger and want to make sure I have the right stuff. The owners manual specifies M2C154-A and I have no idea what that's equivalent to. I have some 80W-90 Valvoline Gear Oil. Is this the right stuff? I also got the additive for the L/S axle to add. Thanks in advance.
Old Jul 30, 2004 | 04:19 PM
Black Ranger
Also is it okay to use a gasket instead of RTV?
Old Jul 30, 2004 | 08:22 PM
Rockledge's Avatar
Rockledge
The Valvoline gear oil is fine.
Old Jul 30, 2004 | 08:45 PM
oppy's Avatar
oppy
Use RTV. If you used a gasket, you'd still need to use a gasket compound anyway, so just save the unnecessary step.
Old Jul 31, 2004 | 12:00 AM
el conquistador's Avatar
el conquistador
rockledge,
i am planning to change my rearend fluid too. i was looking a the mobile 1 synthetic but they only had 75/90. would that be alright for a differential?
Old Jul 31, 2004 | 03:40 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
I changed the rear end oil in my 94 4.0 4x4 supercab yada yada etc 2X so far. First time I used Permatex black and all was well. Ford didn't even offer a gasket. All was fine. Then I changed rear end oil for a second time and I found out Napa had a gasket. BAD MOVE. I installed it and shortly after doing so the rear end cover cracked as evidenced by a leak. I'd strongly suggest using the OEM method; use Permatex black and save yourself a headache
Old Jul 31, 2004 | 07:04 AM
oppy's Avatar
oppy
75W-90 syn is fine as a replacement for 80W-90. Check your owners manual first, because some of the newer trucks use 75W-140.
Old Jul 31, 2004 | 09:52 AM
Black Ranger
Thanks everyone. I got it all changed. I ended up using RTV (permatex orange colored). Having this forum really helps. Thanks again.
tje2015
Jun 15, 2012 04:45 PM
kdeleon
13
Aug 27, 2006 08:47 PM
99Ranger
Sep 29, 2003 12:47 PM
TimH
Jun 16, 2003 08:07 PM
