98 ranger differential service
Old Aug 19, 2006 | 10:43 AM
kdeleon's Avatar
kdeleon
I broke the friggin ABS sensor off on the differential, so now I have to open my differential to try and pop it out. SOOOOOO....service time!
Anyone have the specs for servicing the differential on a 98 ranger 4.0. I need the torque specs for the bolts, and the amount/type of oil to put back in the housing. Also, does it require/recommend any additives? Thanks.
Old Aug 19, 2006 | 10:53 AM
jimdandy's Avatar
jimdandy
Smile
25ftlb or 34 newtons for the cover bolts.
If it is limited slip and you use limited slip gear lube, no friction modifier needed.
If you use standard gear lube you will need to add a bottle of friction modifier about 4oz if I remember correctly.
Look at the tag under one of the cover bolts. The lower left number is the axle ratio and if there is an L in the number it is limited slip. jd
Old Aug 19, 2006 | 10:59 AM
RangerPilot's Avatar
RangerPilot
It's shown like 3 73 for a 3.73 or 3L73 for a limited-slip 3.73. All fluid information can be found in your owner's manual.
When you put the diff cover back on, apply a fairly thick bead of RTV silicone around the entire thing to properly seal it. I used the black stuff. As soon as you apply it, pop the cover into place and put four bolts on it in a box pattern (to keep it securely down). It'll need to sit there until it sets then you can add fluid.
Also, when you have it open, after it drains drain the bottom part of it, fluid won't drain out of that little "ditch" for lack of a better term, so you'll need to find a way to suck it out to properly get all the fluid out.
Old Aug 19, 2006 | 11:13 AM
kdeleon's Avatar
kdeleon
thanks for the help guys...yeah my owners manual is non-existent because I bought the truck used, and they obviously lost the manual. Now hopefully I can get the darn sensor out! I hope the ring isn't in the way. I guess we will see!
Old Aug 19, 2006 | 11:15 AM
kdeleon's Avatar
kdeleon
Oh, and what weight gear oil do I need? synthetic? And do I just fill it up to the plug? Sorry for all the questions...it's my first differential service
Old Aug 19, 2006 | 11:20 AM
jimdandy's Avatar
jimdandy
Smile
You can use RTV if you wish, but I'm a gasket man myself. Clean both surfaces, and I apply gasket tack to the gasket and surfaces. I have had a couple instances where the RTV didn't hold up. jd
Old Aug 19, 2006 | 11:24 AM
jimdandy's Avatar
jimdandy
Smile
80/90 weight
Synthetic is your option. I like it myself.
Fill to bottom of fill plug. jd
Old Aug 19, 2006 | 01:12 PM
monsterbaby's Avatar
monsterbaby
Just for the oppisite side I haven't used a gasket on a diff cover for 20 yrs and only had one time it didn't hold which was my fault for not getting it really clean. Plus it was on a 9" and when putting it together I didn't watch that the rtv stayed in place. But I have also seen other people never have a problem with the gaskets. Just wanted to add that both work and to each his own that works best for him.
Old Aug 19, 2006 | 01:39 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
If you go out and buy a gasket and try to torque down those bolts, you will be in for an unpleasant little surprise. Don't ask me how I know; I'll just say it took a new plastic cover to make things right. They used permatex black for a very good reason. Do not use a gasket as was suggested in post #6, unless you have a metal cover.
Old Aug 19, 2006 | 02:39 PM
jimdandy's Avatar
jimdandy
Smile
Does the 8.8 have a plastic cover? I haven't seen one, but that doesn't mean anything. I have a little experience changing covers (more than one) with gaskets, rtv, and haven't damaged a cover yet. I don't like rtv because its messy, you have to wait for it to dry, it squeezes out all over the place, etc. But, if you like it, use it. jd
Old Aug 19, 2006 | 11:43 PM
RangerPilot
As far as I know, there is no gasket on our diff guys, my owner's manual states to seal it with a silicone-based sealing agent (RTV or the like).
As Cowboy said, permatex black, a GOOD heavy bead, all the way around, and plenty of torque on the bolts. A mess to clean up around the edges is better than it not sealing properly and doing it again (been there, done that!).
Old Aug 20, 2006 | 10:26 AM
jimdandy's Avatar
jimdandy
Smile
Interesting that your owners manual gives instructions for the owner on taking some of the vehicle apart for general maintenance when the shop manual says do it otherwise.
Draining and Filling
1. Drive the vehicle for 16-24 km (10-15 miles) at highway speeds to warm the rear axle lubricant to operating temperature and minimum viscosity.
2. Raise the vehicle on a hoist and place a drain pan under the rear axle (4001) to be drained.
3. Clean the filler plug area of the axle housing cover (4033) or carrier to prevent possible entry of rust, dirt, etc. into the rear axle assembly (4006).
4. Remove the axle lubricant fill plug. The fill plug is located in the carrier.
5. Using a suitable suction-type utility pump (manual or powered), drain the rear axle lubricant from the axle by inserting the pump suction hose through the axle filler plug hole down into the lowest portion of the carrier and removing all the lubricant.
6. Fill the axle housing with the specified amount and type of lubricant as shown in the Specifications portion of this section.
7. Install the filler plug. On Ford rear axles, tighten the filler plug to 20-40 N-m (15-30 ft-lb).
It's personal preference, I prefer gaskets, and if installed properly, there is no problem.
Old Aug 27, 2006 | 05:56 PM
kdeleon's Avatar
kdeleon
For future reference...I used 80/90W synth...and it takes about 3quarts. Got the sensor out...truck still broke...going to post another thread.
Old Aug 27, 2006 | 08:47 PM
RangerPilot
funny also that yours doesn't mention pulling the rear cover. I'd never trust the draining ability of a little pump. I remove the cover to let most of it drain, and drain the rest out of the "tub" at the bottom with a pump. So it's bone dry, I know it's bone dry, and I can inspect everything.
KevinC.
Jul 17, 2010 12:09 PM
spdjunke
May 27, 2004 09:15 PM
mauleace
Dec 12, 2003 11:41 AM
rangercape
Jul 2, 2003 02:58 PM
kev100
Mar 13, 2003 07:13 PM
