Feed back would be appreciated
Hello. I have a 95 F150 302 w/ OD. I'm not so much interested in speed as I am power. I'm continually pulling a heavy horse trailer and find that this truck does not have sufficent power to do so. It has been recommend by others that I try installing the Hypertech power module for this truck (I've already installed the K&N Cold Air Intake-to no avial-sounds neat mind you). Has anyone had any experience with this product (Hypertech in general) and if so....did it help?
Any feedback would be appreciated.
Thanks
Thanks
If you're seriously going to be pulling even a small horse trailer, a 1/2 ton likely will not suffice, especially not a 302 powered truck, you need a diesel, or big block to pull that kind of load.
Delta chip or non-switch chip, same programming, same power. Delta lets you have more than one setting, that's the only big difference between them.
On sale here:
http://www.motorhaven.com/customer/home.php?cat=37
On sale here: http://www.motorhaven.com/customer/home.php?cat=37
J Drew
Computer Chips & Tuners
13
Apr 10, 2002 10:43 PM
