Aerostar Ford Aerostar
A4ld reverse problem
Old Sep 15, 2004 | 02:03 PM
goldenii27's Avatar
goldenii27
I'm hoping that the vacuum modulator will help with another problem of smoothly changing gear up as sometimes the engine has to accelarate before changing the gear.
Thanks Again Robert.
Old Sep 17, 2004 | 01:07 PM
SgtJoe's Avatar
SgtJoe
If there is fluid in the vacuum tube, then it is bad. And it will cause exactly what you are describing.
Old Sep 17, 2004 | 05:42 PM
Mikeman's Avatar
Mikeman
I knew I had this filed away somewhere, it just took me a while to find it.
Try this: http://www.atcdg.com/TechBulletins/bull_122.htm
This bulletin tells you to replace the reverse piston seal with an old style C-6 double lip seal.
Old Sep 20, 2004 | 08:44 AM
goldenii27's Avatar
goldenii27
I really appreciate the picture/diagram. I'm still waiting for the part (the servo) from Ford. I will take some picture to make this job easier for further members.
Thank You.
Robert
mtnmx
Feb 22, 2017 11:25 AM
Sbroom
17
Nov 16, 2015 12:20 PM
Anthonynoble
Mar 21, 2015 02:51 PM
tulsatonyfan
1997 - 2003 F150
Nov 19, 2011 11:40 PM
gjnicholas
1978 - 1996 Big Bronco
35
Mar 25, 2011 11:01 AM
