Need Header Help
Old Jul 28, 2004 | 01:26 AM
ilikefordtrucks's Avatar
ilikefordtrucks
Need Header Help
Hi guys, i was wonderin' if you could tell me what headers I need for my truck. I have a 65 f250 4x4 with a 352. I have seen headers listed for 65 2 wheel drive or 66 4 wheel drive, but not 65 4 wheel drive. I know the 65 4x4 was kind of an oddball, so i am hoping you can help, thanks.
Old Aug 7, 2004 | 12:51 PM
dinosaurfan's Avatar
dinosaurfan
header help
Ilike, have you loked at Stan's, FPA's or Sanderson's ? I'm betting any one of them could fit you up. DF
Old Aug 7, 2004 | 06:34 PM
Alz Ryde's Avatar
Alz Ryde
Question
I don't know if your '65 has the rear eng/bellhousing mount/crossmember like my '63 has, but I ordered some Sandersons for it. Thats been 3 weeks now, I keep hearing " will be there Fri for sure ". If and when they get here, for those with pre '65 trucks with an FE engine, I'll be able to offer some input as far as fit. If you want to check them out, go to Sanderson's site and look up FF427, or FF390, that will give you an idea. There ph# is 1 800 669 2430, there on pacific time. Al
Old Aug 7, 2004 | 08:42 PM
FORD352V8's Avatar
FORD352V8
get hedmans. They are the best of the cheap header brands. And they make headers for your application too.
Old Aug 9, 2004 | 11:37 PM
ilikefordtrucks
thanks for the help
Thanks for the nudge in the right direction. The hedmans are by far the cheapest so I will most likely get a set of those. I see they list 65-76 as the years that their headers fit. I will be giving them a call in the morning to make sure they fit my truck and then probably order them. Thanks again, Jim.
