need help with oxygen sensor..97 Expedition
Old Jul 27, 2004 | 11:18 PM
Judah's Avatar
Judah
Question need help with oxygen sensor..97 Expedition
My check engine light is on so I used a OBDII to check it out on my 97 Expedition. It says its the sensor in the front "bank#2", I don't know which one it is, Passenger side or driver side? If its the passenger side it looks very difficult to replace. How do I get it off? Is there a special tool to remove and replace the oxygen sensors? Should I replace all of them at the same time? I don't know what to do. Any advice will help, Thanks.
Old Jul 28, 2004 | 07:26 AM
itlkick's Avatar
itlkick
Bank 2 is the drivers side and it is easier to replace.
To do the passenger side the easiest way is to remove the starter. The connector is hard to get to (attached to the back of the head) so sometimes it is easiest to remove the inner fender as well.
The driver side is much easier - lucky you!
Old Jul 28, 2004 | 09:01 AM
NoMo's Avatar
NoMo
I'd wait until the others fail before replacing them.
They make a special socket for O2 sensors, but I've never used it. I've always just soaked the area in penetrating oil and used a wrench. It's been a while since I changed one so I can't remember if you are supposed to use anti-sieze or not. Maybe someone will come along here and let us know for sure.
Old Jul 28, 2004 | 09:20 AM
itlkick's Avatar
itlkick
I always use a wrench, not the socket.
Yes, put anti-sieze on the threads when you put the new one back in.
Old Aug 2, 2004 | 02:18 PM
Judah's Avatar
Judah
Thanks NoMo and itlkick I found the special o2 sensor socket wrench at a local auto parts supply for rent. It worked out perfect, I changed the sensor and the check engine light went off. Thanks again for the help and info.
Old Aug 2, 2004 | 07:05 PM
radtec's Avatar
radtec
I use anti seize on everything you never know when you will have to take it apart again before you sell. My rotors on my 97 EB fell off when I replaced the brakes the second time no sledge hammer needed.
wikdwest
Jul 20, 2014 01:54 PM
wikdwest
Jul 19, 2014 12:12 AM
welbo97
Nov 15, 2008 06:33 PM
Don D
1997 - 2003 F150
Jan 16, 2007 07:14 PM
xc007
Jan 24, 2006 09:20 PM
