FOB Programming
Old Feb 19, 2002 | 10:33 AM
4x4_EB_Explorer's Avatar
4x4_EB_Explorer
FOB Programming
Hi to all:
I've been reading trough the forums and I have found this topic posted many times; but somehow I cannot get it to work. What am I doing wrong here? I have 3 different FOBs (one was from a jaguar) and I cannot program them right. Does the kind of FOB has to do anything? What do I must look first in a FOB that it will work or match on my 95 EB?
This is the procedure I've been following: Brand new FOBs, by the way.
1. Get the remotes.
2. switch form on - off position 5 times (i get the confirmation on the locks) {I have the door open at this point, could this affect?}
3. Press a button on the remote {Any button?}
4. No confirmation after I pressed the button.
Please help me. How does a "FORD" FOB should look like?
Thanks a lot!
Old Feb 20, 2002 | 12:38 PM
reberhardt's Avatar
reberhardt
FOB Programming
Your procedure is correct and the cycling of your locks indicates you do have keyless entry. You must use a remote from a '95-'97 Explorer. A remote from a '98 and up Explorer definately will not work and I don't even know if '94 and earlier Explorers offered keyless entry. A remote from another manufacturer will not work either. The remote you want is the Ford remote with 3 buttons on it. They are labeled with the words "Lock", "Unlock" & "Panic". The newer remotes have symbols instead of the words, they won't work.
Old Feb 20, 2002 | 04:00 PM
4x4_EB_Explorer
FOB Programming
Thank you, finally I got it right thanks to you. Definetly I was doing it with new type remotes.
Old Feb 21, 2002 | 10:13 AM
kevins's Avatar
kevins
FOB Programming
ride_red
2004 - 2008 F150
Jun 15, 2015 06:22 PM
steveg_nh
Nov 26, 2014 11:31 PM
stash46
Nov 26, 2011 12:49 PM
