Intake monifold gasket
Old Jul 27, 2004 | 03:34 PM
R J F's Avatar
R J F
Question Intake monifold gasket
How hard is it to replace the gasket on my inline six 93 f150
Old Jul 27, 2004 | 09:51 PM
sandrat's Avatar
sandrat
Upper or lower? Upper, easy, lower, not so easy. Guessing it's probably the lower (intake to cyl. head) The intake itself comes off easily enough, but correct me if I'm wrong, but I believe the exhaust manifold gasket and intake gasket are one unit. Removing the exhaust manifolds can be evil sometimes. Might have to seperate the upper and lower intakes, which isn't hard, but it's one more gasket you'll need. Good luck.
Old Jul 28, 2004 | 01:13 PM
R J F's Avatar
R J F
Sandrat, thanks for your help
Old Aug 1, 2004 | 09:54 PM
R J F's Avatar
R J F
Like to thank you people for your help with this vacum problem. However I did go to a garage and got the repair done. ($380.00) A side problem that I have had for two years . A vibration that comes and goes has not come back again after the vacum repair. The truck would vibrate at any speed and leave if I have it more gas or let up on the gas. My truck hasn't run this good in years. I didn't know a vacum problem could cause so many headaches. The truck runs so smooth that when I stop in gear it feels like it stalled. Thanks Again R J F
Frankmyers
Feb 10, 2015 09:49 AM
oscajo
Apr 9, 2014 09:03 AM
Guyf
May 17, 2005 08:53 PM
getnbz
Apr 18, 2004 05:48 PM
66worktruck
Jan 10, 2001 12:45 PM
