75 F250: Engine Cranks But Won't Start...
Hi...I fount this site by searching the web about my problem....
I just replaced the fuel pump yesterday, There is gas in the tanks, new battery & cabels, new spark plugs, wires, cap & rotor. Fuel filters are 6 months old. It has always had a hard time starting even after replacing everything but the fuel pump. So, when it pulled this stunt I automatically figured fuel pump, but when I pulled it out it looked brand new!!!! I changed it anyway, but doubted that would fix it, and I was right. Any other suggestions? I have good spark, but it doesn't seem to be getting gas to the carb. HELP!!!!!!
Go get a can of starter fluid. If it will hit on that, then you do have a fuel problem. Then start at the carb and work back to the tank. If it will not hit on the starter fluid then you have a ignition problem. You say you have good spark, but how strong is it? Can you hold a plug a 1/4 inch off ground and throw a nice blue spark. I have seen times when you would be a spark, but it was not strong enough to fire under compression. It that is the case check the coil and the dizzy.
Look for a pinched fuel line or you might have dirt and or rust in the tank so even though you replaced the filter it might be clogged again. You can buy the cheap clear plastic filters and see if it is getting clogged if so gotta drop the tank and clean her out.
Check for gas getting to the carb by looking down the throat and moving the throttle. If gas squirts into the carb then you got fuel. Pull a plug wire and check for spark. If no spark, it might be the ignition amplifier if you have duraspark. If no duraspark then check the points and condensor.
Dreamsickle
Hook a vaccuum gauge to the suction side of the pump and see if it is drawing. I have run from a jerry can to rule out the lines and tank further back. The spark needs to be checked with a spark tester, since we all have different opionions of what "good spark" is. KD makes a nice one.
Hope this helps.
Dreamsickle
Hope this helps. Dreamsickle
Found the problem.... The Fuel Tank Selector Valve. I started by checking hoses, suction, filters, carb. everything checked out. When I got underneath to look at the lines coming off the tanks, I noticed the valve was so rusted, that chunks of it were falling off. Then I remembered that the truck dies everytime I switch tanks, and won't start for 5 -10 min. afterwards. I took a chance, changed it out, and it started up better than before. Thanks guys!!!
I having trouble starting my 75 F350 after running out of gas. I put in 10 gallons but no luck. Changed the coil pulled every spark plug and cleaned new wires. I can see gas in gas filter cranks but won't start. I shot it with starter fluid and no luck.
edit: also, since you ran your tank completely empty, that puts you at a higher risk of having sucked some debris into your fuel filter or lines (or possibly past the filter into the carb).
Is the gas moving inside the filter? You might just have air in the lines, and if it's a rear tank, then the fuel has quite a ways to travel before it provides pressure at your carburetor.
And it would've been OK if you'd started a new thread...
Although these old threads are cool, because I always like to click on the profile of screen names which I don't recognize, and see when they last logged in or posted to the site...
429 in my 76 highboy won't turn over
I got the truck running and then replaced the starter, starter relay switch, alternator, battery and all of the cables . . . I'm grounded from the battery to the block, and from the block to the frame rail
lights come on, hazard lights work, radio works
brake light was coming on when key was turned, but now it's not
nuetral safety switch?
how do I access this?
I see no apparent screws below the steering wheel
Help!
Jersey
Help!
Jersey
