Transmission swapping
Old Jul 27, 2004 | 02:21 AM
Dalamatition's Avatar
Dalamatition
Hello. Have any of you ever gone from a E40D to a C4 or a C6?
Old Jul 29, 2004 | 06:22 PM
RTM's Avatar
RTM
I have only read post on the swap and you will need to change your computer but to what I have no clue. It's no a straight forward swap, drive shafts will also be different lengths.
Old Jul 30, 2004 | 12:21 AM
clarko's Avatar
clarko
Gotta switch to a 89 or earlier computer before E4OD's were around.
Old Jul 30, 2004 | 12:24 AM
KwikFord's Avatar
KwikFord
or you can switch to manual trans computer!
Old Jul 30, 2004 | 01:42 AM
Dalamatition
I'm interested in a C4 transmission because it has less drivetrain robbery. Would that be even more difficult than a C6 conversion?
Old Jul 30, 2004 | 03:36 AM
clarko's Avatar
clarko
Which engine?? You'll need a transmission crossmember too from an early 80s truck with a C4 and a kickdown cable from the same engine as the computer and harness too.
Old Jul 30, 2004 | 03:40 AM
Dalamatition
It has a 5.0 in it.
Old Jul 30, 2004 | 03:43 AM
clarko's Avatar
clarko
Yeah the C4 will work with a 5.0 but not a 5.8. See if you can find the crossmember out of a 80-84 truck of the same model as yours (i.e. F-150). Quick question though, why would you want to lose your overdrive?
Old Jul 30, 2004 | 03:53 AM
Dalamatition
Gear Vendors makes a attatchment that replaces the tailshaft. It gives the transmission 3 more forward drive gears.
Old Jul 30, 2004 | 04:10 AM
clarko's Avatar
clarko
Yeah but that costs a lot
Old Jul 30, 2004 | 10:16 PM
SoCalDesertRider's Avatar
SoCalDesertRider
To the tune of about 3000 dollars with driveline length mod... www.gearvendors.com
Old Jul 31, 2004 | 03:11 AM
clarko's Avatar
clarko
Can you say, I'd stick with the E4OD?
