valve lash
Old Jul 26, 2004 | 06:22 PM
palmrose2's Avatar
palmrose2
valve lash
OK so I know that the proper way to adjust lash is to use different length pushrods. What would happen if I shimmed under the fulcrum if I needed a shorter rod or ground some off of the fulcrum if I needed a longer rod?
Old Jul 26, 2004 | 06:44 PM
mark a.'s Avatar
mark a.
You probably could grind them some, but it would have to be done on a surface grinder. You can usualy shim them .03 safely. but you should check the geometry afterwards. It's important that the rocker tip sweep the valve tip evenly or you will have excessive rocker, valve tip, & guide wear.
Old Jul 27, 2004 | 09:17 AM
beartracks's Avatar
beartracks
You can get shims from Crane cams to raise the fulcrum. Push rods too if you know the length. In the past you could get push rods from Ford in .030 longer/shorter.
crazy96863
20
May 25, 2013 12:28 AM
bradford237
Sep 26, 2012 06:42 PM
the Canadian
Dec 25, 2010 10:10 PM
Steve78
Sep 4, 2006 10:44 PM
turbogus
Oct 28, 2002 11:13 AM
