Leaking c6 at selector lever
Old Jul 26, 2004 | 10:13 AM
KJKozak2's Avatar
KJKozak2
Hi all,
My C6 is leaking and my Haynes manual is no help. It's leaking where the selector lever goes into the tranny. It's right where the switch is for the reverse lights is. There's a nut on there that's pretty loose but I can't find any torque specs on it.
Is that one of the band adjustments or is it just for the selector lever? Should I just crank it down or is it supposed to be loose?
Thanks in advance!
Kevin K.
Old Jul 26, 2004 | 12:55 PM
ecarter50's Avatar
ecarter50
That nut is for the downshift(passing gear) lever. Should be 12-16 ft-lbs.
Old Jul 26, 2004 | 01:12 PM
KJKozak2's Avatar
KJKozak2
Thanks!
There's no lever on mine except behind the switch for the gear selector. Should there be another lever on the outside of the switch?
I don't have the downshift rod from the carb to the tranny so the lever might be missing too.
Thanks again!
Kevin K.
Old Jul 26, 2004 | 06:15 PM
mark a.'s Avatar
mark a.
The kickdown lever has a O ring behind it that seals the shaft, without it the O ring has nothing to seal against.
Old Jul 30, 2004 | 09:17 AM
1968stepside's Avatar
1968stepside
So, how do you replace that seal? I have a C4 that is doing the same thing at the shift selector shaft. I have the replacement seal and cannot find anything on it in Haynes or Detroit Iron manuals.
Old Jul 30, 2004 | 09:45 AM
KJKozak2's Avatar
KJKozak2
Good question!
I did tighten the nut to specs and it stopped leaking. Don't know for how long though. I'm sure I'll have to replace the o-ring sooner or later.
Thanks for the help guys!
Kevin K.
greenf150flareside
Jan 27, 2018 05:38 PM
FJB_6989
Oct 10, 2015 08:57 AM
finlander42
Dec 1, 2014 07:18 AM
Dracoscott
Aerostar
May 19, 2012 10:15 AM
bigolebluef150
Nov 20, 2006 03:09 PM
