Hood adjustment
Old Jul 26, 2004 | 09:11 AM
beartracks's Avatar
beartracks
Hood adjustment
I could use some advise on getting my hood to come down all the way in the back. I just replaced the springs and hinges seem good. I tried loosening the bolts and holding the hood all the way up while tightening but that doesn't seem to work
Old Jul 26, 2004 | 09:24 AM
73Custom's Avatar
73Custom
My hood sticks up when the hinges are too dry. Some good lube and it closes correctly.
Marty
KJKozak2's Avatar
KJKozak2
There was a post several months ago about this same thing. If I remember correctly, the trick is to tilt the hinges back a little to get the spring to pull down.
I think this is how I did it:
Tighten the bolts with the hinges in the lowest position.
Close the hood and make sure the hinges aren't too low.
Loosen the front bolt and move the front of the hinge up and retighten it.
Again, if I remember correctly, this worked for me.
Good luck.
Kevin K.
Old Jul 26, 2004 | 09:58 PM
stephenw's Avatar
stephenw
Both of the previous comments will get you on the way. If you look at the linkage on the hinge, you will see that you need to get the hinge to "break over center" in order to allow the hood to lower. In other words, if the hood is sitting too high, "probably" you need to either raise or move the hinge forward a little to make it break over. If you study it a little, it will make more sense than trying to explain it, and it's kind of counter-intuitive. And lubrication is essential!
Good Luck! I think all of us have been in your shoes at least once! Steve
Old Jul 27, 2004 | 09:05 AM
beartracks's Avatar
beartracks
Thanks, I'll try it again after I get back from the drags in Sonoma. next week.
Old Jul 27, 2004 | 09:13 AM
ethomps's Avatar
ethomps
What type of 'lube' do you all use for your hinges?
I just went to the garage and adjusted the front end of my hinges up (as recommended) and it brought my hood down.... thanks.
What should I use to lubricate the hinges?
Thanks. Eric
Old Jul 27, 2004 | 09:26 AM
KJKozak2's Avatar
KJKozak2
I've been using that spray-on white lithium grease for lots of stuff and it works pretty good. You could also use some spray silicone, but the grease is thicker and I think it lasts longer.
Kevin K.
Old Jul 27, 2004 | 01:43 PM
offroadbronco's Avatar
offroadbronco
just remember that everything is opposite with the hinges. bringing the hinges up lowers the hood, down raises the hood.
tip49
Sep 18, 2021 06:46 PM
tyrantsparky
Dec 22, 2013 10:22 PM
r_reed
Aug 21, 2011 06:30 PM
cumminpwr11
Apr 19, 2006 11:15 PM
Narwhal
19
Oct 18, 2005 03:02 PM
