Decoding
Old Jul 25, 2004 | 08:39 PM
'78 Custom's Avatar
'78 Custom
Decoding
Where can I find the meanings for the codes on the rating plate on the drivers side door? I have the owners manual but i cannot find anything about it although it says the information is on a certain page, but it is not.
Old Jul 25, 2004 | 08:57 PM
javi2001's Avatar
javi2001
Have a look at:
http://www.medicine.wisc.edu/~mrm/bronco/ftvin.cgi
Old Jul 25, 2004 | 09:17 PM
'78 Custom's Avatar
'78 Custom
thnx man, that did it. and one more thing, is 2.72 good for rear axle?
Old Jul 26, 2004 | 01:18 AM
fordflaresides's Avatar
fordflaresides
For highway crusing it's good, but for towing terrible. Most guys like the 3.55s ro 3.73s as a good balance.
Old Jul 28, 2004 | 04:14 PM
javi2001's Avatar
javi2001
Short Answer... it deppends... on what is the truck's work and also what tranny, engine model and tires size.
In my oppinion I6 engines works nice with E4OD + 3.55 + 31X10.5 tires OR I6 + AOD + 3.55 + 235X7.5 tires
For towing/climbing consider then 3.73 or even 4.1
Old Jul 28, 2004 | 04:32 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
In my opinion, 2.72 gears would be fine with a 300-6, with a T-18 4 speed. For crusing, towing and hauling. Good fuel economy on the highway, and grandma gear for when you need to tow or haul heavy stuff.
Would be awful with a 302 with a automatic.
Old Jul 28, 2004 | 07:13 PM
'78 Custom's Avatar
'78 Custom
Setup is C6 tranny and BFG 255/70R15 8" wide, no overdrive, just reg automatic with 3 running gears
Old Aug 3, 2004 | 02:58 PM
javi2001's Avatar
javi2001
Then 2.72 will work nice on flat higways, I guess around 3 will be better...
Old Aug 4, 2004 | 12:25 AM
83Van's Avatar
83Van
I have a C6 and a 3.00 rear, does fine on flat land but doesn't like hills too much. Tow more than 1500 lbs and it slows to a crawl on any grade. Swapping punkins' to a 3.50 next weekend so I ***hopefully*** can go faster than 35mph uphill w/a load.
