Tapping and no idle
Old Jul 25, 2004 | 08:29 PM
Powerglide350's Avatar
Powerglide350
Tapping and no idle
I just picked up an 83 F-100 with the 300 I-6. The truck will not idle unless I keep my foot on the gas. (I tried turning the idle up on the carb but as soon as I kick it down the truck shuts off. The engine is also tapping quite a bit.
The valve cover was very loose so I tightened it down and it is about 1 quart low on oil. The spark plugs looked good. I'm sorry but I am familiar with Chevy engines and these Fords are new to me. Thanks in advance for any help you can offer.
Old Jul 26, 2004 | 01:06 AM
fordflaresides's Avatar
fordflaresides
The tapping noise would suggest to me either it needs a valve job or it has a loose rocker arm(s). Especially since the valve cover was already loose someone might have already tried finding if a rocker arm was loose, they should be tight enough so that there is no up or down movement in the pushrods but you should be able to twist them, overtightening will bend a pushrod.
Old Jul 26, 2004 | 02:10 PM
Powerglide350
Could the valves be adjusted wrong and be hanging open? Could that be why it won't idle?
Old Jul 26, 2004 | 02:52 PM
fordflaresides
The valves should be self-adjusting but they could be sticking.
granny_rocket
Dec 23, 2012 08:15 PM
rickylee75160
Oct 11, 2010 11:31 AM
El_Rodney
May 10, 2009 07:52 PM
gappy
Nov 10, 2008 03:03 PM
miked79928
Mar 1, 2005 11:53 AM
